Hydraulic temp. of my excavator is high after 30 mins. of operation only? What is the posible cause of this problem? Tnx
    Genius:
  • 1,015 Answers
If you haven't done so already I would drain all hydraulic fluid after it is warmed up a little. Change any filters and refill with industrial grade fluid. I have had similar problem with my old backhoe when I used cheap fluid and filters. Hope this helps you. Thank you
Posted on Mar 30, 2011
Yanmar b15 excavator Boom and arm will not operate. everything else works fine. HELP.
Is there an interlock on the boom that wont allow it to operate if the front blade is not set? There could be an issue with hydraulic fluid, pump or PTO.
Feb 08, 2017 | Cars & Trucks
What does the exhaust temp high operate carefully code mean on the kx40 excavator
It means the engine is in danger of damage from heavy loading. Ease up on it and work slower.
Jun 01, 2016 | Cars & Trucks
Why won't my excavator stop overheating?
Search Results
    Solving Hydraulic System Overheating Problems
    www.machinerylubrication.com/Read/680/hydraulic-overheating
    Overheating ranks No. 2 in the list of most common problems with hydraulic equipment. Unlike leaks, which rank No. 1, the causes of overheating and its ...
    Cat 320 overheating - Heavy Equipment Forums
    www.heavyequipmentforums.com/showthread.php?2828...overheating
    Mar 28, 2007 - 15 posts - ‎10 authors Anyone here have a problem with a Cat 320 overheating? ... that many heatingproblems in excavators are caused by hydraulic problems. 5T Excavator KX161-3 overheating
    Apr 22, 2013
    john deere 270D excavator over heat
    Aug 1, 2011
    cat 305CR overheating issue
    Jul 23, 2011
    cat 312 overheating
    Jul 31, 2008
    More results from www.heavyequipmentforums.com
Oct 14, 2015 | Cars & Trucks
What causes a mini excavator (Yanmar B27) on rubber tracks to shudder and shake ( bunny hops) when first moving forward or reverse? Would worn track rollers produce this effect? Thx
probably not--This sounds like uneven pressure from the hydraulic pump or problems with the drive motors. Check that the hydraulic oil filter is in good condition (not blocked) and have the pressure in the hydraulics checked.. Have the hydraulic controls checked for correct operation. (if electric controls check for voltage problems to the solenoids and if manual check for control valve problems)
Oct 05, 2014 | Cars & Trucks
Kobelco sr135 excavator won't slew right or left.
You have an hydraulic problem in most likeyhood. Check the fluid level, check the lines. I don't know exactly what a Kobelco is, but anytime a contractors piece of machinery won't slew right or left it has been a hydraulic fluid problem.
May 10, 2014 | Liebherr Excavator
Takes a long time to heat up inside
I Was Gonna Ask If There Is Thermostat In There ?
Being a 2014 Its Under Warranty - Get It To The Dealer
Dec 11, 2013 | 2014 Kia Sorento
Running Eatons 700-011 hydrostatic transmission in Walker Ride-on Mower. Lose drive pressure and steering on one side when unit has been operating for 30 mins or so. Oil levels ok.
Hydraulic pressure regulator for that side could be going bad. Fluid pressure is being bypass from that circuit causing hydraulic pressure loss in drive and steering.
Sep 25, 2013 | Garden
I have a 7-41 I.R. compressor. Recently serviced with 1200 hrs done. It now only runs for about 20 mins before shutting down. After 15 mins she starts again. I have tried bypassing water temp sender and...
make sure the cooler(s) are clean. Next check the airend discharge temperature switch commonly called a HAT (High Air Temp) switch. These switches will reset as the compressor cools down. I would be able to access the switch quickly. Run unit until shutdown remove wires and see if switch is open. if open you found your problem
Jun 01, 2011 | Ingersoll Air Tools & Compressors
Possible problem of slow movement of Hydraulic cylinder and Travel of Komatsu excavator
hi, have u checked ur fluid and filter, if so u need to check the pressure.
u can buy a normal guage and and get a bit of pipe made up to suit ur job.
you might be able to get away by increasing the spool valve. but if ran low on hydraulic then it is a new pump.
Aug 29, 2009 | Norscot Group/Cat Norscot Group 1/87 Ho...
Heating & Cooling Logo
113 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
