Question about Tappan Dishwashers
Tappan dishwasher model 611144 washing pump works and will not drain. no plugs in drain hose.
  • 641 Answers
SOURCE: Dishwasher isn't draining
It could be the pump, but not only. Check first that you don't have any clog in the drain line. If drain line is clean, open machine's rear panel and : - Look if the pump works. If it doesn't work check that pump get power (with multi-meter). In case it get power (and does't work), it should be replaced. - In case the pump works - The machine has a drain valve with an electric solenoid (the drain pipe connected to it). When it get power the valve opens and diverts the water to the drain line. Test that it get power. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck !
Posted on May 29, 2006
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
SOURCE: pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Posted on Jan 05, 2009
  • 10865 Answers
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Posted on May 28, 2009
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Posted on Oct 25, 2009
My dishwasher will not drain! Where is the drain located? Please help!
Your dishwasher may have a simple 'drain hose plugged' problem.
Check this first.
The drain hose leads out of the dishwasher to a drain, normally under
the kitchen sink. Pull this line from the dishwasher off its connection
on the drain (Nomally just a clamp of some sort) and make sure it does
not have something caught in the line, like a piece of food or something.
You could even shove a wire up the hose line after its off to make sure it
is not plugged farther up the hose line.
If this looks to be clear of abstruction, then you will need to pull the
dishwasher out of its cabinet position and inspect the underneath
of the dishwasher. If the line looks attached and no leaks or broken line,
then it may be the dishwasher pump it self that is faulty. One other thing to check
first before you call a repair man to replace the pump, is make sure you
have power to the pump. There should be an electrical connection
to the pump. Make sure it is attached, therefore power to the pump.
If it is not attached it may have just come lose, and it would be a simple fix.
OTHERWISE - - this ll fails, call your local service repair man to replace
the drain pump.
Feb 25, 2011 | Tappan Dishwashers
Maytag dishwasher mdb50awq won't drain
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Sep 05, 2009 | Maytag Washing Machines
Potscrubber 900 Dishwasher won't drain
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Aug 27, 2009 | Dishwashers
My frigidaire dishwasher routinely leaves some water in the bottom after it is finished washing and the dishes are always wet on the top
2. Broken belt
3. Pump
Jul 19, 2009 | Dishwashers
ADP 4502/5 not working,not draining water,start
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jul 13, 2009 | Dishwashers
Dishwasher will not drain. had to install a pump kit because the macerator blade had stripped off. It rinses good now but still will not drain. The drain solenoid works well
OK, check the following areas to combat this issue further.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 18, 2009 | GE Dishwashers
GE Nautilius Dishwasher - Water will not drain out after washing
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Apr 23, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher will not Drain
Some of that porcelain is in the pump which drains the dishwasher. This is an easy job but you will need a phillips head screw driver.
Remove the lower front panel and you will see the drain hose. The end of the drain hose at the base of the dishwasher is connected to the drain pump. Loosen the clamp and remove the drain hose. Check the hose for pieces of porcelain. Next remove the drain pump and look inside of it. I am quite sure you will find a piece of porcelain in there. Remove it and reconnect everything. That should solve your problem.
Feb 07, 2009 | Tappan 18 in. MDR251RE Built-in Dishwasher
My dishwasher does not completely drain after a wash. what do i do?
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off
Jan 08, 2009 | GE Nautilus 24" Built-in Dishwasher
Whirlpool dishwasher
Well you have three things to look at
simple things first. Is the drain hose clogged Gunk builds up in these hoses and can cause the pump to fail after awhile. if connected to garbage disposal .... is this draining.Take the hose off and clean or blow or replace.
Filter clogged or missing, The filter keeps the pump from getting gooberd up. small pieces of plastic and glass or whatever will either kill your pump or just jamb it up.
can you hear the pump trying to work????
Quiet turn everything off and listen for the pump to work.
Aug 03, 2008 | Tappan 18 in. MDR251RE Built-in Dishwasher
Dishwashers Logo
64 people viewed this question
Top Tappan Dishwashers Experts
Ronald Rissel
Melissa Martin
Melissa Martin
Trevor Turner
Are you a Tappan Dishwasher Expert? Answer questions, earn points and help others
