Question about HP Laserjet CM2320nf All-In-One Color Printer
HP CM 2320 nf MFP keeps saying...... fax line is busy....
I had this problem as well - try the following:
1) Change your rings-to-answer from the default of "1" to "3". This is found in the basic fax setup on the control panel of the printer itself.
This solved the problem for receiving faxes that I was having when testing fax reception by the HP 2320nf from an dedicated fax. The remote fax would fail after repeated rings with a "BUSY" indication in the fax error report it printed. "BUSY" equals either actually "busy" or also it can mean "no answer".
What I found on the 2320nf end was that it had detected an inbound fax but never answered it. The color LCD on it had "fax received" but the device itself appeared hung.
Hope this helps.
Posted on Apr 04, 2011
Is there a way to hook up my hp lazer jet pro m1212 nf mfp to be able to send a fax utiling my laptop which is by wifi. In other words no land line available.
Without a dial-up line available for your fax machine, the only other way to fax is via the internet if it's supported by your MFP. Google online faxing or fax via internet for solutions you may be able to use in your situation.
HISTORY
Fax or facsimile was invented as a way to take a printed document, scan it into digital form and transmit it to it's destination in a matter of seconds -vs- sending it via an expensive courier taking hours or days. This is before the internet, Adobe and other players made a way to create and send documents via the internet without the need for a fax machine and dedicated phone line. While faxes may still be sent that way when the printed document is the only media available, faxing has died off considerably. Most large companies now have ways implemented to move documents digitally without the need to fax. I predict the fax portion of a MFP to disappear in the not too distant future. Earlier MFP's didn't include a fax feature and one had to but the next model up to get it, now it's included in nearly every MFP. Adobe's PDF format with the ability to fill in the forms fields electronically (as in your US taxes) without having to have expensive office software made printing and faxing a thing of the past. Don't be surprised if the business or other entity requests you, and all of us, to submit a PDF document to their business email address rather than a fax.
Good luck with your quest!
Oct 15, 2013 | HP LaserJet Pro M1212nf MFP -...
Hp laser jet m1213nf mfp fax storage memory full
hp laser jet professional m1213 nf mfp fax error repot storage full
Aug 11, 2011 | Panasonic KX-FHD331 Plain Paper Thermal...
Part number for the OPC Drum in a HP toner cartridge CC530A.
That OPC is the same for HP CP1215/1515/1518/2020/1525 CM 1312/2320/1415 cartridges.
No Part number, search OPC HP CP1215/1515/1518/2020/1525 CM 1312/2320/1415.
Jul 04, 2011 | Office Equipment & Supplies
How do i receive fax
Here is the link to HP Official Support site. You can download the User Manual for HP LASERJET M1522 NF MFP Printer. Go to Section 10- Fax (Page 69) for complete and step-by-step instruction for setting up fax.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 06, 2010 | HP LaserJet M1522nf Multifunction Printer...
Hp laserjet M1522 nf MFP printer No Fax receving
Try an nvram. Holdm down the down arrow and the cancel button and turn the printer back on.
Al
Sep 13, 2010 | HP LaserJet M1522nf Multifunction Printer...
I have been unable to send faxes to different numbers for months now. I keep getting Error 344. It always sounds like HP 3050 is able to go as far as establishing the connection and then it fails. Please...
Faxing
  1. Turn Off JBig compression.
  2. Move the fax to another location. It may be that they have noise on the line, an alarm, etc.
  3. Turn ECM Off , turn Off V.34 and set the baud rate to 9,600 or lower.
  4. Ensure fax firmware version is at the latest.
  5. Ensure firmware version for fax matches device firmware.
  6. Ensure that the device is using an analog line and phone cable that came with unit.
  7. Reset fax to factory defaults; configure just the basic settings needed to operate (country code, company name, and fax number).
  8. Reseat fax modem in formatter (or Xircom card if legacy MFP).
  9. Try a disk init. (Contact your regions HP Customer Care Center for these steps)
Aug 03, 2010 | HP LaserJet 3050 All-In-One Printer
HP laserjet M1319f MFP "no fax detected" error
I had the same problem and just solved it by going into Setup - then Fax Setup - then All Faxes - Then Speed - and lowering the speed from fast to medium. Sure it's a couple seconds slower, but it finally works!!!
Dec 02, 2008 | HP LaserJet 3015 All-In-One Printer
HP Laserjet CM2320nf All-In-One Color Printer Logo
618 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
