Question about Kenmore Washing Machines
Kenmore washer 70 series(top loading) only dispenses hot water. Have changed the inlet valve-no help.What is my next step?
  • Kenmore Master
  • 8,220 Answers
The water temperature selection switch would be what I would check next.
Posted on Mar 30, 2011
My Kenmore 70 series washer only fills will hot water
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore 22422 Top Load Washer
The problem is the water inlet valve is clogged or has failed. There is a free video at www.appliancehelponline.com/servicemanual.html this will walk you thru testing this part. It's a different model but testing is the same. There is also another video to show you how to dissassemble this model( whirlpool style). Try cleaning the screens in the hoses and the inlet valve before disassembling.
Mar 28, 2010 | Kenmore 22422 Top Load Washer
Kenmore 70 series, 110 washer leaks water when
Hi, You will need to change the inlet mixer valve. It is sticking open just enough to allow water to drip through it. This should be chandes asap so that it doesn't get bad enough to over flow the washer.
Here are directions on how to remove the cabinet so you can get to the inlet valve.
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series is leaking water. Could it be the pump?
It depends on WHERE the leak is coming from. If the leak is coming from the FRONT area of the washer, the drain pump or drain hoses are suspect. If the leak is coming from the REAR of the washer, the water inlet hoses, water inlet valve, or dispenser hoses may be suspect. If the leak is coming from under the CENTER portion of the wash tub, the tub seal or wash tub may be suspect.
The first step is to remove the exterior washer case to gain access to view. The following link explains how to replace a water pump (if required) on your washer, but also includes all the steps necessary to access the washer interior:
http://www.fixya.com/support/r397092-replacing_water_pump
Allow the washer to fill about 1/3 of the way and turn it off before unplugging and removing the washer casing. The washer will not run once you disconnect the lid switch connector, so you will need some water in the tub to see where the leak may be coming from.
NOTE: If the problem IS a leaking pump, these pumps are not serviceable and will need to replaced.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Jul 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series cold water trickle
Hi, If there is good pressure to the valve and the screens inside the valve are clean, you will need to replace the inlet valve.
Please let me know if I can assist you further with part# or how to replace the valve.
Thanks
Vic
May 24, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Cold water trickle hot water runs good
turn off water valves at wall, disconnect the supply hoses from the washer. where the hoses connect to the washer, there is usually a stainless steel screen/strainer inline on both the hot and cold inlet. corrosion on the cold side is pretty common. Menards, Lowes Home Depot stores sell the replacment screeens.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 top load washer - cold water fill very slowly.
The screens in the line are clogged. There is usually a screen in the washer hose at the point where it is connected to the faucet as well as one by the water inlet valve. NEVER REMOVE THE SCREEN BY THE WATER VALVE. As for the one in the cold water fill hose, that can be cleaned or replaced.
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
INLET WATER VALVE ON BACK BAD,THANKS-MIKE
Jul 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kemore 70 series
Its possible that your trans. is going to need replaced. Maybe have some bad seals on the trans. As far as the water leak goes. Could be a tub seal, maybe some worn inlet hoses, maybe a leaky inlet valve.
We hope this gives you a start on your appliance repair. Anymore questions please feel free to reply back.
Mar 26, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
