Question about Nordic Track NordicTrack Commercial 1500 Treadmill
Nordictrack 1500 stuck at high incline., - Nordic Track NordicTrack Commercial 1500 Treadmill
    New Friend:
  • 326 Answers
You will need to contact Icon Fitness .
Posted on Dec 08, 2013
maxtreadmill
  • 832 Answers
SOURCE: My treadmill is stuck in the max incline position
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Posted on Jun 11, 2010
  • 14 Answers
SOURCE: nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
Posted on Jul 08, 2009
outfield502
  • 79 Answers
SOURCE: Nordictrack Model A2550: Incline function!!??
this function is to give a little more intensity exercise, while helping to raise the heart rate and thus burn fat. watch it more practical as a stress test.can use the runner at a speed of 3.5 mph and an elevation of 7.5 of inclination and see good results
Posted on Feb 09, 2010
  • 218 Answers
SOURCE: My Nordictrack treadmill seems to
it is trying to calibrate itself, let it go the whole way up and then down without interrupting it. Then it should be fine.
Posted on Aug 11, 2010
outfield502
  • 79 Answers
SOURCE: My Nordictrack commercial 1500 is stuck at 12%
need to flip side and with a wrench 1 / 2 or 9 / 16 loosen the screw of motor base and try to press the down key and if so work you should Lift motor replacement
Posted on Sep 15, 2010
My Nordictrack treadmill model T7si is stuck on the 10 incline position. How do I fix it?
Check that the incline plus switch is not jammed or likely there is a defect in the panel circuit causing plus incline to be repeated. This needs to be trouble-shooted by removing and testing the panel circuit.
Oct 07, 2014 | Nordic Track Exercise & Fitness
What is wrong with and how can I fix the incline on my Nordictrack commercial 1750 treadmill?
This sounds as though the motor is bad, they cost around $130.00, ther is a n electronic controller that controls it, but as it is trying to raise I would think that the switch and controller are functioning. Best of luck and please post back f this helps.
May 25, 2014 | Nordic Track Commercial 1750 Treadmill...
Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Nov 17, 2011 | Nordic Track NordicTrack Commercial 1500...
My 1500 incline is stuck at 12% and won't respond to re-calibration
This is something you can fix yourself.
I suggest you get in contact with Icon Fitness.
Apr 04, 2011 | Nordic Track NordicTrack Commercial 1500...
My Nordictrack commercial 1500 is stuck at 12% incline and won't go nor up or down. How do i fix?
Sep 12, 2010 | Nordic Track NordicTrack Commercial 1500...
Feb 02, 2010 | Nordic Track NordicTrack Treadmill, A2550
Incline stuck- keep going up and dopwn. Treadmill
I had the SAME problem, several times, with my NordicTrack A2250 Treadmill.
Allow it to go fully up and then fully down several times, without turning it off. IT seems to "cycle" that way 3 times and then "reboots" itself and starts working normally, again.
I had to figure this out myself... none of the suggestions I read worked.
Oct 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack Commercial 1500 Treadmill Logo
120 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
