Question about Panasonic TCP50S2 50 in. TV
SOUND BUT NO PICTURE...SAME WHEN USING DVD...IS THERE A RESET
  • 643 Answers
To reset unplug tv for atleast 2 hours.
Posted on Mar 30, 2011
I get a picture on my DVD, but no sound, I've asked this question twice now.,
There are a limited number of television and audio engineers that give there time free of charge to help others.
Disconnect the television and the DVD player overnight to reset.
Are you using surround sound? Unplug it and connect direct.
Remove the HDMI cable and turn it around. Check the mute button on the television.Check settings in the DVD settings and the television for 'video only'.
Jun 23, 2017 | Televison & Video
Why do I get 'Video Signal is output from Video Jack shows up' message. The picture does not show but the sound does
Have you been using your DVD player with its video out on your TV for a long time? Did you often switch off your TV while the DVD was still connected? I had a similar problem and had to eventually take the DVD to Sony and they checked and said the mother board needs to be replaced. Thank fully mine was within guaranty so it was repaired for free :) So maybe you might want to take your DVD to the service centre. Best of luck
Jun 16, 2014 | Sony DVP-FX750 Portable DVD Player
Picture but no sound
It is most likely the SAP setting is in place. This will kill the sound
To reset the audio, go to the on-screen menu and select the setting for audio and make sure it is on stereo rather than SAP (second audio channel).
toggle the two and see which is compatible to ur Dvd player
thank you
Apr 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Colby dvd -215 i switched vidio options and cannot see it can it be reset?
try this
*********RESET THE DVD PLAYER BACK TO THE DEFAULT SETTING*********
Make sure you do not have a disk in the tray. Using the DVD player remote control:
1) Press the "Setup" button.
2) On the "Right" arrow, press it three times and then press the "Play" button.
3) On the "Down" arrow, press it two times.
4) On the "Right" arrow, press it once, and then press the "Play" button.
5) Press the Setup button.
*The default setting will take affect as soon as you press the setup button (step 5).
Oct 02, 2008 | Televison & Video
I have connected my DVD/VCR to my Samsung 32 inc television but I get no sound
I had a strange issue yesterday too.
Our Samsung DVD/VCr all in one combo did a similar thing.
I used the HDMI cable for the DVD into the TV input labeled HDMI/DVD. That worked okay.
But the VCR part didn't work.
At one point I got sound but no picture. Using the RCA cables in the back on another input "Component 1"
I was trying to squeeze the best picture out of the player using the S-VHS cable.
I thought it did picture only, but the Plasma seems to be more picky about input sources.
I got everything to work keeping the DVD as a separate HDMI to Plasma TV feed.
The VCR was 3 RCA's Yellow (picture) red and white for stereo sound.
I then reset (toggled through the inputs to "reset" the TV.
It finally worked but I was two days mulling it over.
See if this works for you.
My TV was a Panasonic Plasma, but shouldn't matter.
Skip the S-VHS line and connect the inoputs with the TV off.
You MAy need to go into the input of set up menu on the TV (ours had a wrench as an icon) and set the Component 1 or 2 to "VCR".
Aug 04, 2008 | Samsung Televison & Video
DVD sound but no picture...after pushing progressive scan button
desactivate the progressive scan or if u don't know how to do it, just do a reset on the dvd player.
Dec 29, 2007 | Samsung DVD-V4600 DVD Player/VCR
No DVD Picture
you need to assighn the input for the component video page 78 of your manual will explain how
Dec 28, 2007 | Yamaha RX-V661 Receiver
DVD picture flashes on & off
our problem was because the hdmi on reciever was not compatable with hdmi on dvd player, different versions ex. 1.2, 1.3 , 1.1
ended up using component inputs instead
Dec 16, 2007 | Toshiba SD-6000
NO PICTURE BUT SOUND
check video connections, what r u using exactly, r u using a receiver, what type of connection u using, patch cord,, component, etc
Nov 19, 2007 | Cyberhome CH-DVD 300 DVD Player
Dvd player-No pic yes sound
Try using the I/P button on the remote. Toggle between S-video, RCA and composite video outputs.
Nov 14, 2007 | Apex Digital AD 1115
Panasonic TCP50S2 50 in. TV Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
