Question about Nikon N5005 35mm SLR Camera
How do you work the self-timer for the Nikon N5005?
    Guru:
  • 406 Answers
Hi there fellow Nikon user. I see that you want to know you can make the self-timer work. I suggest you click on this link: http://www.cameramanuals.org/nikon_pdf/nikon_n5005-2.pdf then go to page 44-45
Enjoy!
Posted on Mar 30, 2011
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Compose the picture, then lightly press the shutter release button to set focus and exposure. Press the self-timer button on the left top of the camera (marked with one-handed clocks) to start the self-timer. If you hold the button down for three seconds you'll get two shots, otherwise just one.
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n5005/nikon_n5005.htm
Testimonial: "Thanks! "
What exposure rating do i put when its dark for a nikon n5005?
By the highest speed ( ASA ) Film you can fine, ASA 1000 if poosible
Apr 26, 2014 | Nikon N5005 35mm SLR Camera
I now use this lens on Nikon N5005 and want to purchase the D5000 camera. Is this lens compatible?
Yes and no. The lens will fit on the D5000 without a problem. But the sensor on the D5000 is smaller than a frame of 35mm film so you'll end up using only the center portion of the image. What this amounts to is that the lens will act like a 115-450 zoom would on the N5005. Also, if the lens doesn't have a focus motor built in (Sigma calls it HSM) then it won't autofocus on the D5000. You can still focus manually, though.
Sep 30, 2010 | Sigma 75-300mm f/4-5.6 DL Lens for Nikon...
I have a Nikno n5005. I have never used this camera before and would like to know how I can find out if the flash works
you will get all the information about a flash work and more through you user manual
if you don't have user manual download it from this link below
http://www.devicemanuals.com/guide/Cameras/Nikon/Nikon-N5005-Instruction-Manual-TmpNek9UST.html
Sep 21, 2010 | Cameras
Cannot turn OFF self timer mode on Nikon coolpix 8400.
Press the self-timer button (marked with a one-handed clock) once for ten-second delay, twice for three-second delay, three times to cancel timer.
Jan 11, 2010 | Nikon Coolpix 8400 Digital Camera
Can you tell me the best choice in a telephoto for NiKon N5005 ca
try looking for a cheap 70-300mm AF-D i'm not sure it the AF-G version (no aperture ring, control via body) will work with your cam.
Dec 22, 2009 | Nikon N5005 35mm SLR Camera
Need a new back door for Nikon n5005
Nikon no longer sells that part. You can check eBay foe a used door, or maybe a parts camera. UScamera.com sells a repair kit to fix the latch on the door you have.
Dec 15, 2009 | Nikon N5005 35mm SLR Camera
Self timer for the nikon n55
Press the self-timer button just to the right of the LCD panel and confirm that the self-timer icon appears. Press the shutter release halfway to focus and meter. Press the shutter the rest of the way to activate.To cancel, either turn the camera off or press the self-timer button until the self-timer icon disappears.
You can get a manual at http://www.butkus.org/chinon/nikon.htm
Jul 13, 2009 | Nikon Photography
N5005 will not advance film when loading.
As I stated in a second posting, I found that the previous owner had left leaky batteries in the camera. when I removed the bottom cover I found some corrosion on the bottom of the motor gear assembly.I' m thinking of trying to remove the motor assembly and see if it's free. What led me to the motor was the fact that when I tried to load film and it did not wind I set the camera down for about 5 to 10 minutes. when I came back and picked up the camera, I noticed that the motor drive battery area was very warm. This led me to remove the bottom of the camera. Seeing the rust on the gears makes me think some might be stuck. If that's the case, I'm going to try and see if I can free them and go from there.
Dec 08, 2008 | Nikon N5005 35mm SLR Camera
Help!!!!
Remove the lens from camera.
Look inside pass the mirror, how is the shutter?
Should be flat with the film with no warp or opened shutters.
Or try this:
Lens out, set camera to M (manual mode).
Shutter set at 1 (One Second).
No flash.
800 ISO
Lnes drive pin (recessed) fully into the body, not S or C.
Fresh batteries.
Set self timer on.
Press shutter button.
Camera should blink and then shutter should be tripped.
This will also check to see if you have enough power for min. of one shot.
atdlee@netzero.com
Jan 22, 2008 | Nikon N5005 35mm SLR Camera
Nikon N5005 - No Shutter Release
The lens aperure ring must be set to the highest number, ( IE, smallest aperture, f22,f32 ) for the camera to work in full auto. Also, with the ASA set to DX, the camera will not release without film.
Nov 26, 2007 | Nikon N5005 35mm SLR Camera
Nikon N5005 35mm SLR Camera Logo
142 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
