Question about Tissot V8 T36.1.426.52 Wrist Watch
On my Tissot v8 the 1/10 counter isn't exactly on 0 (it's a little past and I want to adjust it but don't know how?.I also want to set the counter from the "seconds" counter (the bottom right circle) to 60 and the 30 minutes counter to also be at the 12 o clock position and not move, thankyou in advance for any help you can give.
SOURCE: tissot t touch, time problem
you need to calibrate it.
go to the '24h Cm' screen [T button, then touch centre screen few times]
hold down T button for 5secs
use + button to bring minute hand to 12 o clock position
use - button to bring hour hand to the same place
press centre of screen and it's done!
Phil
Posted on Aug 06, 2008
escapement
  • 2334 Answers
SOURCE: SMALL SECOND HAND DOES DOESN'T GO CLOCKWISE HOW DO I FIX THIS?
Go to www.tissot.ch
Posted on Dec 17, 2008
  • 183 Answers
SOURCE: Tissot PRS 200 hour and mnute hands not advancing.
I may not be clear on the problem here but it sounds like you may only need a battery change. If the battery is not the problem you can ask that your watch by placed on a cyclonic to force the gear train and free up small particle(s) that might be holding it up. This will be the fastest and least expensive. There is the chance this may require a more complicated repair but this till give you a starting point.
I suggest going to a watchmaker/technician who is familiar with working on this brand and be able to seal the watch back to its water resistant rating. This will take having a pressure chamber on site.
Posted on Sep 25, 2009
OhioTrucker
  • 33 Answers
SOURCE: watch hour and minute hands are not lined up at 12 o'clock
Take the back off, then slip the works out of the case. move the hands to line up at 12.. hope this helps..
Posted on Feb 27, 2010
SOURCE: My tissot prs 200 30 minute counter wont reset to zero
http://www.youtube.com/watch?v=3bvJWgBRVI8&feature=related here is the best answer for you.
Posted on Jul 19, 2010
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Jan 29, 2013 | Tissot T-Touch T33159851 Wrist Watch
I have a Tissot Automatic PR 516 from the early 70s. Time is kept well. Date moves forward correctly but it is the wrong date. I am unable to turn back the date. I am able to turn back the day. Any...
The crown wheel (winder) should have 3 positions, (1) the normal winding position (3) fully out; at this position the watch stops and the time can be adjusted.
(2) This position is between the 1 & 2 and is used to adjust the day and date. If you wish to change the date by winding the crown backwards or forwards.
Since watches can very a little, if turning the crown when in position 2 the date does not change, pull the crown to position 3 and turn the hands until you pass the midnight position, when the date will change and then re-set the time. If you wish to advance the time more than one day, when it changes, wind the crown backwards past the midnight position and then wind it forwards again. Repeat until the correct date is showing and then re-set the time. The exact distance you need to turn the crown to change the date will have to be found by experimenting!
Feb 06, 2011 | Watches
How fix the time ?
you mean how to set the time?
screw crown? if yes, turn the crown to loosen counter clockwise.
pull gently day and date adjust
pull gently again time set
Dec 14, 2010 | Tissot TXL T60.1.588.51 Wrist Watch
I dont know how to adjust time
You can download a manual or contact Tissot direct at this link:
http://support.tissot.ch/
Best regards
Aug 19, 2010 | Tissot T-Touch T33159851 Wrist Watch
Im trying to adjust the time because it stopped when i took it off for a day. Im not sure how i can change it because the adjusting knob is not popping out.
mcdevito75 here, Tissot a very, very great name and watch, a you know most stems pull out to set the time, some watches have a screw down crown this adds to it"s waterproofing as there is a gasket under the crown. Maybe your Tissot has this screw down crown, simply un screw the crown then gently pull up on the crown to set the time. If this fails, see any Jewler for help, doN't mess with the watch to much a syou or anyone could wreck it, and Tissot is very expensive.
Jun 24, 2010 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
My tissot toch hour and minutes are out of sync for instance at 10:45 it appears like the hour is on or past 11. Is their any way to re-sync them or reset them.
This is an expected, needed adjustment, and is addressed in the manual:
http://www.tissot.ch/data/usersmanual/138-en.pdf
Syncronisation
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Sep 11, 2009 | Tissot T-Touch T33759851
Tissot PRS 200 cannot reset counter hand (the counter stuck especially in the morning)
The owners manual mentions how to fix this but the instructions are not 100% clear. You can download the PRS200 manual here:
http://www.tissot.ch/data/usersmanual/134-en.pdf
Each of the 3 chrono hands are reset separately. Unscrew the crown and pull it all the way out (2 stops out). Press button A (top right) as many times as necessary until the hand is on the 30. Each press moves the hand one tick so you may need to press it several times.
Next push in the crown one click.
Press button B (bottom right) as many times as necessary to advance the 60 second hand to 12'oclock.
Press button A to advance the 1/10th hand to 0.
The part I did not get at first is the fact that you need to press the A and B buttons several times to advance each hand 1 tick at a time until they are all pointing to 12'oclock.
Oct 22, 2007 | Raymond Weil W1
Tissot watch prs 516 automatic
I would recommend going to the following link and follow the instructions for resetting the counters and see if that corrects the issue.
Jun 19, 2007 | Tissot PRS 516 T91142651 Wrist Watch
Tissot V8 T36.1.426.52 Wrist Watch Logo
254 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Mohamed Ismail
Mohamed Ismail
Are you a Tissot Watch Expert? Answer questions, earn points and help others
