Question about Tecumseh Enduro Horizontal Engine 5 HP 2532in x 2 2532in Tapered Sha
I accdently put deiciel in my go kart and i dont know how to clean the engine
    Genius:
  • 1,015 Answers
If you did not run it much or better yet not at all you probably have not done much damage. First I would remove fuel tank from motor and drain thourghly.Leave tank off and put a small amount of gas in it and shake it around to cover entire inside,then drain out.I would do this 2-3 times then blow out with air and leave cap off to allow gas to evaporate.
Remove sparkplug wire and plug from motor.Remove float cup from bottom of carb and leave off for now.Remove and replace fuel filter if so equipped.I would go ahead and drain and refill oil at this time. Pull starter cord several times.This should force most any fuel out.Put gas tank back on and put a small amount of gas in it while float cup is still off.Put float cup back on and put more gas in tank, maybe a quart. With plug still out pull starter cord several times until you start gettin gas spitting out. Wipe everthing dry and wait for any gas to evaporate before installing plug.
Install plug and hook plug wire back on. Try to start as you normally would. You may get a fair amount of smoke from exhaust but this should clear up in a few seconds. Best of luck to you and thank you.
Posted on Mar 30, 2011
  • 4,340 Answers
Remove the fuel line to the carb and drain all diesel out, flush with new gas. You will need to drop the carb float bowl to drain out diesel from it. Consider allowing some fuel to flow out to flush the inlet passageway, put it all back together and start it up.
2011 ford fiesta p011E and p0071
Here's a link to code P011e. Definition of code P011E You can look up the other one,k.
Jun 10, 2015 | 2011 Ford Fiesta
All my games work on my wii. I just got mario kart brand new! It gets detected and once I select it from the wii menu i get a message that says "the game disc could not be read" I performed an...
its ok dont worrie wash the game disk a little in water then put liquawd soap on it then rub the soap around the whole disk after that wash with water untill all the soap is gone then dry the disk then try playing it again :) hope this is good luck bye
Nov 27, 2010 | Nintendo Mario Kart (Wii) for Wii
I restarted my ar and i put the name of the game and is asking me the id of the game and i dont know what to put
well, it depends what game u r playing, but just google search (The game you play here) then put game id so ex: (mario kart is example game) Mario Kart Ds Action Replay Game ID
Dec 06, 2009 | Nintendo DS Lite Console
Honda cbr250r problems
Hi and welcome to FixYa,
Perhaps you could try here for a wiring diagram.
Good luck and thank you for asking FixYa.
Jul 15, 2009 | 1997 Honda CBR 250 RR
Starting a yamaha kt 100 go kart engine
just bought this go kart , the guy said it was a yamaha kt 100 2t 2 stoke but i have no clue about this motor , is it a good one
May 27, 2009 | KONFTEL 100 Audio Conference
Carbie tuning
Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Don't be chincy with the spray. You probably have a varnish buildup that is stubborn to remove. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Be sure the bolts are tight. Let the float bowl fill then start the engine. Set the idle speed with the idle screw. This process should get you back on the road.
Please rate this solution. Thanks!
Mar 29, 2009 | 2003 Yamaha YZ 125
No English instructions for Wii Mario Kart
i dont think so man ur gonna have to get anothre copy srry
Feb 01, 2009 | Nintendo Mario Kart (Wii) for Wii
ENGINE RUNS BUT NO POWER
IT COULD BE MORE THAN ONE THING,,, FIRST CHECK COMPRESSION, IF IT HAS LESS THAT 80 lbs THAT IT,,, PUT IN NEW RIGS,, IF IT HAS COMPRESSION, THE TAIL PIPE COULD BE STOPED UP,, IF NOT,,, 2 STROKE ENGINE'S HAVR REEVE PLATES, THEY COULD BE BAD,, REPLACE THEM,,, THE CARBERATOR COULD BE IT IF ALL THE OTHER THINGS ARE GOOD, MY BEST GUSS IS,,,,,,IT NEEDS RINGS,, LARRYFRANKUM6780@SBCGLOBAL.NET LET ME KNOW,,,
Dec 10, 2008 | KONFTEL 100 Audio Conference
Yamaha kt100 kart
I've never seen a KT100 before, but i've worked with similar engines.
The fuel isn't gravity fed. It uses a pulse pump system using diaphragms in the carburettor to sort of "**** and blow" the fuel using pressure impulses and valves to stop the fuel going backwards.
The first place you should look is if there is a short pipe from the crankcase to the carb so that the pressure pulses from the case can move the diaphragms. You should be able to see this from some pics on google images. If thats all ok, you should check if the carb is perfectly clean. If its still giving you problems, change the diaphragms in the carb. You should be able to get a replacement rebuild kit from a dealer.
Jun 09, 2008 | KONFTEL 100 Audio Conference
Tecumseh Enduro Horizontal Engine  5 HP 2532in x 2 2532in Tapered Sha Logo
126 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
