Question about Kenmore Dryers
I have 9 yr old Kenmore elite dryer, model 110 82822101. Had Sears repair man out. dryer is clean, vent is good, moister senser is getting juice. worked for a load or 2, then problem returned. Dryer runs, heats, tumbles, but stops way before clothes are dry. this happens on both automatic and manual settings. Problem seems to be intermittent. wiring? short? HELP
  • karolh Mar 31, 2011
    I don't know how this works!! My kenmore dryer problem cannot be just the heat sensers since the dryer shuts off early even on the manual settings. the Sears repairman cleaned the sensers.
  • 4,323 Answers
Hi
I believe that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the dryer belt and idler pulley...Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 31, 2011
  • Kenmore Master
  • 8,220 Answers
Well the dryer control thinks the clothes are dry. As the wet clothes rub against those moisture sensing bars the wetness discharges a capacitor on the dryness board. As the clothes get dry the wetness is no longer detected so the control thinks all is kosher and heads towards the finish line. Get some Windex and clean up those sensing bars. Put the Alabama shine and the Mississippi Gloss on them sensing bars then retry.
http://www.youtube.com/watch?v=rtATa0a28bE&feature=player_embeddedI have 9 yr old - themobilian_2100.jpg
How to get into the dryer:
Posted on Mar 30, 2011
My Kenmore Elite HE4 dryer keeps shutting off after a few minutes.
are u saying it shuts down or just stops heating? if it shuts down u may have bad motor windings and or brushes and motor is burning out if its stops heating that is usually due to bad moister sensor, cycling thermostat ( which would not usually shut appliance off though), short in heating element, defective hi limit thermostat etc and of course u already said u cleaned lint and ducts? including the blower? if its blocked with lint u have a shut off issue
Jul 09, 2015 | Kenmore Elite HE4 Electric Dryer
How to clean lint out of a kenmore elite gas dryer?
Professionally Dryer need to be taken apart some.
by removing front of dryer and removing inner tub
.having a good shop vacuum. and a paint brush .We have a service and charge $65 come out and clean dryer and venting.
heavy lint build up in dryer normally means improper venting.
all domestic dryer venting should never go over 8 ft vertical venting the less turns the better and if vent go's up you need induced venting another fan to help dryer push air Sears website will have brake down on your dryer not a hard job if your good with tools
Jul 05, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
Sears kenmore elite oasis dryer 110 67032600 check lint screen flashes doesn t heat
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Mar 11, 2011 | Kenmore Elite Oasis ST 6807 Dryer
My Kenmore Elite dryer works except there is no heat to dry.I am looking for suggestions to repair. Thanks
There is a moister sensor in your dryer that detects any lint build up inside the exhaust vents. If any obstruction is inside the exhaust tubes this sensor will put the heat in the check mode. Inspect and clean thoroughly and see if it will heat up again
Aug 03, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite gas dryer will not heat
clean out any lint build up in the exhaust vent tubes
the moister sensor will put the heat in check if clogged up
Aug 01, 2010 | Kenmore 63942 Dryer
Sears Kenmore gas dryer not heating up
Remove all duct work and inspect for lint trapped inside. If you get a very good handful the moister sensor shuts down the burner automaticlly until the vents are cleaned thoroughly
May 03, 2010 | Dryers
Wrinkled closes
make sure your washer is spinning the water completley out of the clothes. winkles are caused by moister and if there is a lot of moister in the dryer than it will winkle.
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
Brown streaks
Hi thanks for the question-yes if the venting is not good ,you dryer will take 3 times as long to dry the clothes. its a must to have a clean venting. clean all venting thanks the appliance doc
May 12, 2008 | Kenmore 73952 Gas Dryer
Not starting 1 yr old kenmore elite smartheat quietpak9 HE4
SEE VIDEO
http://www.youtube.com/watch?v=tq3k22cqjR8
Control panel moisture 9/10 times.... or check the fuse under the lower front panel ($12 sears)
Nov 28, 2006 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
207 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
