Question about Cfm Daikin R410a Split System Air Conditioner
Aircon model FHYC125KVE (indoor) aircon cannot switch on...and a icon of a drop water with a froze inside is flashing what is the problem?
    Scholar:
  • 133 Answers
It may be low on refrigerant.
Posted on Mar 31, 2011
Flash doesn't work. Flash icon shows on screen but doesn't fire.
It is detecting it has enough light and not flashing. Look for an "indoor" or other appropriate mode for what you are shooting since most Samsung cameras have them. The flash will only go off when the camera thinks it is needed. Canon Cameras are useless indoors but Samsung's are pretty good indoors when you find the right setting. Their latest models have dozens of modes, most of which you will never use. They are just VERY slow to take pictures. It appears to be cheaper version of their WB250F I had for a while.
P.S. - Never drop a Sansung camera. They will chip and even get damaged from as little as a foot or so. I had one fall about a foot onto pavement and it was permanently ruined. Their older models also stop with lens out when the battery dies but the Galaxy Cam is finally smart enough to retract the lens before the battery dies. It alos does so when shutting down unlike the older models.
Apr 16, 2015 | Samsung ST-200 16 Megapixel Digital Camera...
LG aircon operation light flashes 8 times and then shifts to timer light flashes 4times and then back again to operation light but aircon is not operating.
jz on the aircon manuly on inside the front door.lift the front on the indoor unit there the on/off button,jz press it.don't use remote it can help u
Apr 20, 2014 | LG Heating & Cooling
Water coming from aircon inside
Typically a blocked evaporator drain. Remove filter and inspect the drain pan which is below the radiator looking bit. Clear any obvious blockage around the outlet. Alternatively, find the drain outlet and blow back up it gently. This can be done with compressed air or similar. Take a photo of the indoor / incar unit and post it here if you are still stuck.
Dec 22, 2012 | Dometic Rooftop RV Air Conditioner
TCL air conditioner works for about 15 minutes, switches off and gives a signal of 4 red flashes every now and then.
It's due to abnormality of out door unit. Clean condenser coil first. Check run amps. If gradually increases, replace running capacitor. Check rpm of f.motor. If slow, replace fan capacitor. If still problem, replace fan motor. Service indoor unit also. Thanks.
Feb 04, 2011 | Heating & Cooling
Water flowing inside the room thru indoor unit
blocked drain
low gas charge
cracked drain pan in head unit
Apr 21, 2010 | LG LS-K1830CL Cool Mini Split Air...
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Indoor unit light blinking ( first n second light from top)
I have the same problem too. Aircon cannot switch on, two lights from the top is blinking. Everytime I turn on, the flip is open then close again with sound. The technician said the thermostat cable need to be replace. It cost about $15. The cable is 14" long. Hope this help.
Feb 16, 2010 | Samsung Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Cfm Daikin R410a Split System Air Conditioner Logo
410 people viewed this question
Top Cfm Heating & Cooling Experts
David Payne
David Payne
Brett Duxbury
Brett Duxbury
Thomas Woodburn
Thomas Woodburn
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
