Question about Lindhaus RX Hepa Bagged Upright Vacuum
My Lindhaus evolution vacuum turns on but I cant vacuum the rug, the beater wont turn. There is suction through the hose. I took the beater out and put it back in, still nothing.
rickzilla
  • 706 Answers
SOURCE: vacuum turns on and suction
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Posted on Aug 14, 2008
  • 8 Answers
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
you need a new belt and maybe a new brushbar.
Posted on Dec 23, 2008
SOURCE: bad suction on bissell powerforce bagless vacuum
I took the bottom apart and it needed a new belt and that was the problem so it's fixed.
Posted on Jan 17, 2009
SOURCE: Powerhead woes
I've had my Hoover S3755 for about 2 years and loved it, at least until the last couple of months when the "belt slipping off" problem started. I changed the belt and the vacuum would work for a little while then the belt would come off again. I put on a new belt again and within minutes the belt had slipped off. I took it to my local vacuum repair about 4:00 in the afternoon. By 4:45 I got a call from the repairman that he'd fixed my vacuum! What did he do? He put a different belt on it. He put a Rainbow belt on my Hoover that's thicker and doesn't have as much "give" as the Hoover belt. It's also a little bit wider than the Hoover belt. Now when the brush slows or stops at a carpet edge the belt doesn't slide off.
Posted on Jan 31, 2009
SOURCE: Dyson DC07 hose has no suction
Just resolved the same problem...couldn't find a blockage anywhere, but pulled handle out of hose and extended hose as far as possible upward. Aha! There was blockage in the hose at the very bottom where the flexible hose meets the rigid part.. There is a lever which releases the entry to the bottom of the hose. A pencil, lots of coins, a crumpled receipt and general dirt were stuck. Easy to clean and now it works like new again.
Posted on Aug 09, 2009
Suction when vacuuming
Some vacuums have a valve or collar near the handle that you can twist to adjust the amount of suction on the vacuum. If you open it a little it will stop sucking up your throw rugs. IF the problem is not enough vacuum then the HEPA filter may be clogged. It's usually a rectangular filter in a plastic frame. That has to be changed occasionally or the suction of the vacuum will continue to drop off.
Apr 04, 2015 | Vacuums
I have strong hose suction but none below and beater bar is not turning
Beater Bar Belt Likely Broken--Can Be Checked By Removing Cover(s) Next To Beater Bar (on bottom)
Feb 27, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
VACUUM BEATER BAR WONT TURN AND NO SUCTION ON FLOOR. LOTS OF SUCTION FROM HOSE.
If the belt is stretched it will not pick up properly. Try replacing the belt first. Belts should be replaced at least twice per year.
Feb 24, 2015 | Bissell PowerGlide Deluxe Pet...
The suction comes on but the motor doesnt turn the beater bar nor does the red or green light come on
check to make sure power is coming from wall with a voltage meter, if not wiring issue or blown motor or wiring around beater motor
Feb 28, 2014 | Lindhaus Vacuums
When the dyson is turned on the suction goes to the wand when you tip the beater down you do not have as much suction you cant pick up lint.
The Dyson system is designed to operate the hose with the handle in the upright position. When the head is tipped down (floor vacuum position) it closes the opening to the hose/wand
Nov 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction in hose
Remove the machine side of the hose--is there suction at the machine? If so, run a broom handle or similar through the hose to dislodge the clog. If no suction at the machine, you may need to fish out debris with a hooked stiff wire from the port. Remove the bag and examine the port area underneath for similar clogging. Finally, check the brush area underneath the machine bottom plate for more obstruction. Also, check the brush assembly for debris accumulation. Remove the drive belt and check for free turning of the brush. If turns hard, remove the brush, clean the bearings and roller pins, then apply a small quantity of light oil like 3-1 or sewing machine oil. Hope this helps!
Jun 20, 2010 | Lindhaus 380 Diamante Bagged Upright...
My Lindhaus Diamante 300 has great suction but clogs
Sounds like you have some form of an obstruction in the hose ( i once found a tooth pick sideways in mine) most models allow for the hose to be disconnected from the vaccum itself, also make sure theres not a setting for attachments also, some models need the suction redirected.
Apr 08, 2010 | Lindhaus Diamante 300 Upright Vacuum
No suction for rugs but the hose works fine. Removed the canister and suction is at that point
Remove the base plate and beater bar. Clean the suction cavity behind the beater bar. That's where they almost always plug up.
--W.D--
Aug 19, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hoover U6476-910 - Very little suction from the bottom
If you haven't already, remove the beater bar. This is accomplished by unplugging the vacuum and turning it beater bar up. Remove the clips or screws that hold the plate on the beater bar and set aside. The beater bar sits in sockets, so carefully remove the bar, noting the correct position of the sockets. This will make reassembly much easier. Slip the beater bar out of the drive belt. Now, inspect the suction cavity that the beater bar would discharge into. Usually, things clog up here as there is a flex hose that catches things, creating a pluggage.
Hope this helps, --W/D--
Jul 18, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Lindhaus RX Hepa Bagged Upright Vacuum Logo
26 people viewed this question
Top Lindhaus Vacuums Experts
JoeVacs
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
