Question about Kenmore Refrigerators
Had ice accumlated on bottom of my freezer. Removed all food and took ice out. What caused this?
Defrost drain tube is pluged.Each time it goes into self defrost the water backs up and collects in the bottem and freezes.
Posted on Mar 30, 2011
  • rebcorf Mar 30, 2011
    Thanks for you help. Where is the drain tube located?
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
2002 amana bottom freezer full of frost took food out turned off freezer now what ? ice maker never installed !
Is the thermostat set too high? Does it ever turn off?
It could be the door seals, check to see if intact, if so, could need cleaning so they seat properly.
Finally, should there be draw covers, which have been removed?
Oct 01, 2012 | Amana ABB1927DE Bottom Freezer...
Freezer not maintaining it's temperature
make sure you melted accumlated ice and also the thermostat should be replaced by a new one
Apr 02, 2012 | KitchenAid Refrigerators
Maytag mff2258vew2 french door bottom freezer leaks
The cabinet heater in freezer is may not be working and causing condensation on the walls of the freezer. Have it checked by a service man.. also make sure the refrigerator is level. and it is not over packed with food. Newer models must have a certain amount of space for the air to circulate.
Oct 04, 2017 | Maytag Refrigerators
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
The bottom of my fridge is frozen alonge with the fridge food
Hi sir
it bis thgermostat problem,(heating element),,,so the heating is not done properly by thermostat,,so u should check iot,,,
thank u,,,please rate it,.,,,
Jun 30, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Refrigerators Logo
130 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
