Question about Nikon COOLPIX L20 Digital Camera
ERRORE OBIETTIVO - Nikon COOLPIX L20 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
My cam fell on the floor,and ive seen its lens misaligned.i cant use it anymore ....on screen,,,, it appears LENS ERROR....pls help me,,,im in laguna area,,,and i dont know where to find nikon repair...
Your camera lens is already misaligned, so that Lens Error occur, it will not disappear unless the lens is disassemble, aligned the mechanism of lens ( the proper synchronication of mechanical parts) and assemble.
If you cannot do it, send it to the your nearest camera service center, call them first if they can accept repair on your Nikon Coolpix S210, how much, if repaired how many months will be the warranty.
I hope my advice help you.
Jun 11, 2011 | Nikon Coolpix S210 Digital Camera
Non legge alcuni DVD-R. Legge solo DVD-RAM della Panasonic, oggi difficilmente in commercio.
Ciao
Non so quanti anni il vostro Panasonic DMR ?. In ogni caso, mettere una testa di pulizia disco in ad esso, e giocare per almeno tre volte. Se Laser Pickup Lens ? passato sporco, di questo tipo di guasto pu? verificarsi. Durante il lungo periodo di conservazione o inutilizzati micosi condizione si verifica ad esso e l'obiettivo sar? un po 'opeque. Fate questo per primo. Se questo non ti aiuta, sostituire la sua Laser Pickup Unit? con lo stesso tipo e numero. Insistere su stesso tipo e numero, in quanto ? un componente crtical a voi dispositivo r. OK.
May 28, 2011 | Panasonic DMR-E85H DVD Recorder
My photocopy of canon ir3100f the give massage code error on screen i want solution
Wich code?
Here is examples:
E000 Insufficient temperature rise of the fixing unit at power-on
E001 Abnormality of the fixing unit
E002 Insufficient temperature rise of the fixing unit
E003 Low temperature of the fixing unit after standby
E004 Error of the protection circuit in the fixing unit
E006 Connection error of the fixing unit
E008 Life expectancy of the fixing roller
E010 Main motor error
E012 Drum motor error
E013 ITB waste toner full error
E014 Fixing motor error
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
E021 Developing rotary error
E026 Toner empty error
E032 The counter of the NE controller fails to operate.
E045 OHP sensor error
E067 High voltage-related error
E070 ITB HP detection error
E100 BD error
E110 Operation error of the laser scanner motor
E202 CIS unit HP detection error
E225 CIS light quantity error
E227 Power supply error in the reader unit
E243 Control panel unit error
E248 Backup memory error
E315 Abnormality of image data
E351 Main controller PCB error
E400 Feeder communication error
E490 Model error
E500 Finisher communication error
E503 *** Finisher internal communication error
E505 Finisher backup memory error
E514 *** Stack delivery error / **** End assist motor error
E519 **** Gear change motor error
E530 *** Rear alignment error / **** Front alignment error
E531 Staple error
E532 Staple unit shift error
E535 Swing error
E537 *** Front alignment error / **** Rear alignment error
E540 *** Stack tray up/down error / **** Upper tray up/down error
E542 **** Lower tray up/down error
E577 *** Paddle error
E580 Stack tray up/down error
E584 **** Shutter unit error
E590 ***** Puncher motor error
E591 ***** Puncher dust sensor error
E592 ***** Puncher side registration sensor error
E593 ***** Puncher shift motor error
E5F0 **** Saddle paper positioning error
E5F1 **** Saddle paper folder error
E5F2 **** Saddle guide error
E5F3 **** Saddle alignment error
E5F4 **** Saddle rear side staple error
E5F5 **** Saddle front side staple error
E5F6 **** Saddle paper push-on error
E5F8 **** Saddle connector error
E5F9 **** Saddle switch error
E601 Abnormality of image memory
E602 Hard disk error
E604 The image memory (SDRAM) is faulty/insufficient
E609 * Abnormal low temperature of the hard disk
E610 ** Failure in the hard disk cryptographic key
E674 FAX board communication error
E677 Abnormality of the external controller
E712 Communication error between the ADF and the reader
E713 Communication error between the finisher and the printer
E717 Communication error with the NE controller
E719 Communication error with the coin vender/card reader
E730 PDL error
E731 UFR PCB error
E732 Reader communication error
E733 Printer communication error
E740 Abnormality of the Ethernet board
E744 Language file/BootROM error
E745 * Token ring board error
E746 * Option board error
E747 Main controller PCB error (Image processing ASIC or memory control/communication control
ASIC)
E748 ** Main controller PCB error
E749 ** Restart in accordance with a change of the product configuration
E803 Door close error
E804 Controller fan error
E805 Fan error
Jun 26, 2010 | Canon iRC3100 Printer
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Focus error
The lens is having a problem in the track. That can be similar and possibly the same as lens error. that could be caused by dirt or sand inside the camera. What happens is that the dirt or sand can get on the track which has oil or other lubricant and will cause problems with focus and other lens errors.
See my posts on these problems.
You may try to pull the lens as it starts and then push it as you turn it off.
This may also cause more damage, but can be worth a try.
Mar 15, 2008 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L20 Digital Camera Logo
142 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
