Question about Brother PQ1500S Computerized Sewing Machine
The machine will not stay threaded. When I remove it from the Grace quilt frame it works great. However when mounted on the quilt frame the machine won't stay threaded. Once I have threaded it I can sew one row on the quilt then the thread breaks at the needle and comes unthreaded. I have followed the instructions that came with the machine. I thread it the same both off the frame and on the frame.
SOURCE: thread breaking and terrible looping on backside of quilt.
I had same problem, the manual says to use left twist thread, it made difference, and thread made in germany is left twist
Posted on Sep 28, 2008
  • 3 Answers
SOURCE: needle thread breaks while quilting on machine frame
I think you might have better luck if you use 40 or 50 weight thread.
Posted on Dec 20, 2008
SOURCE: janome 1600P
My husband and I worked for months trying to solve this problem and FINALLY we did it. I even had a YLI varigated thread in the top and Coats and Clark varigated in the bobbin. The machine Janome 1600P DB makes a beautiful stitch. This is a long posting and if you have questions I'll be happy to help if I can. together425@pennswoods.net
1) I give credit to piecemealquilts.wordpress.com for their recommendations.
Most of which I list below.
2) First of all make sure that the frame is level in all directions, side-to-side, top to bottom. That includes the table that it is setting on.
3) Bobbin tension: This is much looser than you normally have it set on. The bobbin should fall steadily to the floor. Read your machine manual to learn how to loosen the tension. Be sure to go in small increments. Don't be afraid. It also helps to use a different color thread in the bobbin than the top to see the problem. Is the bobbin properly inserted into the bobbin case. Is the bobbin case properly inserted into the machine?
4)Use the correct needle for your machine.
5) Use at least a 14 and a 16 or 18 is even better. Size 20 for specialty threads if you can get a size that large.
6) Make sure that the needle is inserted properly. My machine doesn't have a flat side so proper insertion is challenging. If you can find a straight pin small enough to fit in the eye do so as this helps to determine if the needle is in at the correct angle. The eye of my needle is left to right so I use a sturdy piece of thread, some spray starch on the thread helps it to stay straight. This makes it much easier to determine if the needle is in properly.
7) The pressure foot dial is set on 0
8) The stitch length is set on the longest stitch length. I know that you actually determine the stitch length and some people tell you to have it set on 0, but I found this to work.
9)Threading: Make sure you have the machine threaded correctly. Inoticed that when my thread was breaking that the thread in the take uplever was either out of the thread guides or had crossed each other. Also, sometimes the thread had wrapped itself around the first smallthread guide and/or the outside hole on the pretension thread guide hadwrapped around the bottom of the thread guide. When your thread breaks pull a good 12" out and then cut it off assometimes it has frayed higher up. This will help to reduce continuedbreakage and your frustration. This sounds dumb but still make sure the thread is sitting on the spool properly, that the thread spills off the spool as shown in your machine manual. I found it helpful to place a felt pad underneath the spool of thread. This was just a scrap of felt with a hole cut into it. Check the retractable thread guide which is right over your spool that it is correctly positioned and not twisted around. The thread should easily pull off the spool. I found that my machine worked better if I onlythreaded the two guide holes closest to the machine on the pretension guide.
10)Thread tension: I found that my needle tension had to be much looser than what I was used to anywhere from 1 -3.
11)The quilt: Not too tight and not too loose,too tight and needles and thread break, too loose and it's difficult to move the carriage. Can you poke a finger from the bottom and grip it from the top? I found this a little too loose, but used it as a guide. The side clamps are to keep it straight and not tight.
12)The take up rail should just barely clear the bed of the machine. I found it more accurate to check this with the machine in the middle of the quilt as opposed to one of the ends. Can you fit your fingers between the quilt and the machine bed? Yes, but barely is the answer.
13) I was able to quilt in both directions, but make sure your carriage moves freely in all directions.
14) Make sure the feed dogs are down and ready for free motion.
15) Make sure the presser foot is down and ready for sewing.
16) Check both the bobbin area and the top thread tension area for stray threads. It happens.
17) My last help was to add thread lubricant, but make sure your machine allows it. I just found out that you shouldn't use this on the spool if you have plastic tension discs. Mine are metal, but still I use this sparingly. I run a couple of lines on the spool, let it sit for a few minutes then sew. I don't repeat this for at least an hour of constant sewing.
18) Strangely this also helped, every so often I pulled straight out on both the knobs of the pretension disc and the tension disc. Don't pull the knobs off. This just released the tension of the thread. I didn't adjust it, I just pulled straight out. I didn't rethread it, just released it.
19) Finally, I did discover that I had a burr on my tension disc.How to figure this out, well it works better with two people, but one can do it. Lift up the presser foot, needle is in the highest position, then manually , slowly pull the thread through the needle, listen to the tension disc. You shouldn't hear anything. Watch the tension disc, does the check spring move down? Does it stay down then bounce back up? It shouldn't. Feel the thread as it is being pulled does it have tension on it? If the answer to these questions is yes, take it to the shop and let them fix it. It literally takes 5 mins.
I hope this helps
Posted on Jan 12, 2009
  • 9 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
  • 4 Answers
SOURCE: Needle Thread breaking after about 30 seconds of quilting
Are you threading it correctly? I've had this problem twice, the first few times the thread was wrapped around different items (below the spool holder and then around the needle) the other times I threaded it wrong. Double check that the machine is threaded correctly with the manual. I've missed a step here or there and it does make a difference.
Posted on Jul 29, 2009
I'm wondering whether there are compatibility issues with the Grace Quiltmotion and the different quilt frames. I have a Bernina frame and when I called a dealer, he said he had to check with Bernina to...
I would say there will be compatibility issues. I think you would be better off checking with The Grace company for questions about frame compatibility.
Apr 05, 2014 | Sewing Machines
Thread breakage on Juki TL-2000Qi
There are a few reasons the top thread may break.
- Check the needle plate for damage around the needle hole. Polish any burrs with fine sand paper or a needle file.
Check the hook for damage. If the hook is damaged it can cause the thread to break as it comes off the tip. Be very careful if you must remove burrs from the hook. Changing the shape of the hook tip will cause skipping problems.
Check that the top tension is not too high. The top tension should be set at a medium number
Burrs on the needle plate
Burrs on the hook assembly
Bobbin tension is too tight
Jan 16, 2012 | Sewing Machines
I'm using a Janome 1600 DBX on my Grace quilt frame. It keeps skipping stitches and breaking the thread. I put in a new # 16 Janome needle - made sure it was installed correctly, and tried 30 weight and...
The tension is not right and you are moving the machine to fast. Go back to your 50 weight thread top and bottom. Have you got a quilting foot on and the foot in the down position
Dec 01, 2017 | Janome 1600P-DB Mechanical Sewing Machine
I am trying to sew a quilt on a Grace frame and the needle keeps breaking. Any ideas would be appreciated
It could be you moving the machine to quickly?
I use size 14 or 16 needle.
May 11, 2010 | Juki TL-98Q
When free motion quilting the bobbin thread loops and snarls. The machine is not currently on a frame, but I have a Grace Sturdy Light and want to put the machine in (the quilt is rolled and ready), but I...
Try threading the machine with the presser foot up and see if the loops and snarls go away.........
When the foot is down during the threading, the tension control is closed and the thread cannot enter as it should.
No tension control of the top thread and the bobbin thread cannot connect for a proper stitch.
Mar 12, 2010 | Janome 1600P-DB Mechanical Sewing Machine
Need help in using the grace sure stitch regulator of quilting
I am having irregular stitches on the forward/backward motion. I am using a Janome 16000 P on a Gracie II frame. (I purchased this as a used productin a private sale) Do I need a darning plate to effectively use the Sure Stitch regulator in a free motion mode or with a template?
Mar 04, 2010 | Janome Sewing Machines
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Frame quilting with janome 1600 db
am I right that the feed dogs do not drop on this machine?
Yes, this is correct....but you have to change the needle plate to a thicker one, so the feed dogs will be below the needle plate.
Feb 13, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Brother PQ1500S Computerized Sewing Machine Logo
56 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
