Question about Garmin iQue 3600 GPS Receiver
IQ3600 Dumb old lady here. It will not sync I get the message that I need to turn it on, and connect to computer all of which I have done. I have uninstalled the palm and re installed it, the icon is in the tray, and right click shows local. I need help thanks
  • Garmin Master
  • 6,487 Answers
The first thing to check is to make sure you have the USB connector plugged in to your computer correctly.
Once you have done this, you may need to start the HotSync Manager application by selecting Start/Programs/Palm
Desktop/HotSync Manager on your PC. Then press the HotSync button on the iQue cradle to synchronize. If you are still having trouble with the HotSync process, you may need to reload the drivers for the HotSync process.
You can set these correctly by going to the Control Panel on your computer and then going to the System Icon (Windows XP users will need to make sure they are viewing Classic Mode in their control panel).
Inside of here, you can go to your Device Manager. There could either be a Device Manager tab or a Hardware Tab with the Device Manager as a button on that tab. Once inside the Device Manager, HotSync the unit.
When you do this, you should see a device appear in the Device Manager under Other Devices named Palm Handheld. Double-click on Palm Handheld and then go to the Driver Tab and select Update or Install Driver. This process should fix any HotSync problems you are having.
Hope that helps........
Posted on Aug 04, 2008
  • Garmin Master
  • 13,433 Answers
Hello, can you clarify the problem a little, you said you uninstalled palm, but you posted this under garmin gps receaver. I will be more than happy to help you ones we figure out which device you are trying to use. also while you are at it, could you tell me what windows is your computer, is it XP? thats the most common one these days, or vista?
Thanks,
Ekse
  • 19,396 Answers
Try disconnecting usb from computer and unplug computer power cable from power. If it is a laptop also remove battery. Wait five minutes and plug everything together, it should synch
  • 298 Answers
Is it connected to the pc via usb? Try other usb port like the usb port on the back of your computer if your are using a desktop computer.
My htc desire will no longer sync with my PC it asks to insert disk into drive E
Your solution
Setting up HTC Sync to recognize your phone
After installing, set up HTC Sync to recognize your phone.
1. From the Home screen, press MENU, and then tap Settings > Accounts & sync.
2. On the Connect to PC screen on your phone, tap HTC Sync and then tap Done. Your phone attempts to find HTC Sync on your computer. Wait for a few seconds for the process to finish.
3. If your phone displays a message indicating that it's unable to find HTC Sync, try disconnecting and reconnecting the USB cable, and then repeat step 2.
4. When the Phone Connection Wizard is displayed on your computer, click Next.
Enter the name you want for your phone, and then click Finish.
Check the HTC Sync icon at the bottom-right side of your computer screen. If it appears green in color, that means your phone has successfully connected with your computer and HTC Sync recognizes your phone
If still no go try this .
Unplug the phone from the PC, restart both the phone and the PC. When the PC is done booting, plug your phone in and see if the autorun box pops up.
still if nogo try this .
you have to select disk drive (when plugged in via notification area) to be able to view the drive in windows and htc sync to use htc sync.
May 27, 2011 | HTC Desire Cell Phone
When syncing my iQ3600, I get the following message: system compatibility.c,Line:69,invalid card# I have tried resetting, but the message will not go until I erase all data. The maps etc are still on the...
Contact Garmin Customer Support to resolve this problem.
North America - Consumer Products
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Feb 06, 2010 | Garmin iQue 3600 GPS Receiver
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
Unable to transfer music to my LG Xenon
If you are recieving the message about having to format your memory card when u connect ur xenon to the computer when trying to get pics/vids/music on or off the phone, do this and it should work.
1. go to settings
2. touch "More"
3. touch "connection"
4. touch "USB connection mode"
5. touch "Mass Storage"
Voila now u can copy pictures,videos,music to and from your phone and computer.Hope this helps.
Jul 12, 2009 | LG Xenon GR500 Cell Phone
Palm M515 hot sync problem
I have a similar problem with my m515. I have 3 palms and 2 sync fine but the 3rd isn't even getting to the computer. There is no recognition from the computer that the palm is trying to sync even though I use the same cradle for all palms. The ensuing message is, "the connection between your handeld computer and the desktop could not be established. Please check your setup and try again". My settings are set Local and Cradle/Cable.
Dec 20, 2007 | Palm m515 Handheld
Change Answering Machine message in Lucent 1872 corded phone
Try just pressing down on the greeting button on the answering machine, you will hear the lady say "record greeting" and keep holdong down until you are finished recording the message. When you are done, remove your finger, done!
Nov 19, 2007 | Lands Phones
Sync problem
I assume you use activesync. Check in the options that it is set to synchronise this data. if you have already done this try reinstalling activesync or installing the newest version, 4.0.
Sep 15, 2005 | Dell Axim X3 Pocket PC
Sync problem
I am assuming you use activesync. Check in the options that it is set to synchronise this data. If you have already done this try reinstalling activesync or installing the newest version, 4.0.
Garmin iQue 3600 GPS Receiver Logo
51 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
