Question about GE PFS22SISSS Stainless Steel French Door Refrigerator
PFS22SISBSS CLICKING AND NOT COOLING - GE PFS22SISSS Stainless Steel French Door Refrigerator
    Scholar:
  • 116 Answers
Hi this is the main control board, part # WR55X10942, this should fix your problem.
Thanks for using fixya.com, if this has helped please rate my answer. Thanks!
Posted on Mar 30, 2011
Ge refrigerator pfs22sisbss: How can I tell how old my refrigerator is? It is serial Number GL054099?
Date of manufacture should be on the back of the unit on a tag with serial number, model etc.
Apr 29, 2014 | Refrigerators
Edge star not cooling and clicking sound
the clicking sound may be the condenser fan. if the compressor is running, check to see if there is dust or ice blocking the air flow on the condensor or if the fan is moving slow. this will prevent cooling. remove any obstructions and replace the fan if necessary
Nov 24, 2013 | EdgeStar BWC90SSLT - 84 Can Supreme Cold...
I have a GE Profile French door. Mod pfs22sisbss. It is not cooling enough to keep the programed temp for the fridge or the freezer. I tried using the turbo feature and I can hear a clicking sound and then...
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this help in solving the problem....
Feb 03, 2011 | GE Refrigerators
My ge profile PFS22SISBSS FRIDE IS NOT STAYING COOL WHAT COULD BE THE PROBLEM?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 21, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
GE profile PFS22SISBSS running hot and making a clicking noise for several days
the computer board is bad part number WR55X10942,it's on the back outside wall of the machine
Oct 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Our GE unit pfs22sisbss over under stainless steel refrigerator is not cooling...in both areas. This happened once before and we believed it could have been from the kids leaving the door open. We...
Try switch off the unit and leave it for a day with the doors open, that will defrost the unit fully and switch it on again. Remember not to open the door for at least 12 hrs. to let the unit time to cool down.
May 24, 2009 | Refrigerators
I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PFS22SISSS Stainless Steel French Door Refrigerator Logo
543 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
