Question about Bruder Cat Skid Steer Loader
Ihave 2001 bobcat 863 that will not start .glow plugs are new fuel is coming up to the injectors.It was running yesterday.Any ideas?
4 Suggested Answers
SOURCE: what do you have to remove to get to the fuel tank
for remove the bobcat fuel tank you need remove first the motor or if do you want to clean the fuel tank you only need remove in the botton side the steel bar with 3 screws and remove the fluel tank plug.
Posted on Oct 05, 2009
  • 26 Answers
SOURCE: i have a bobcat 863 it will try to start but wont
makes a click but wont turn over check the starter aint locked up.
Posted on May 10, 2010
SOURCE: I have a bobcat 863,
the fuel intake is from the top of the fuel tank, there is a tube which goes to the bottom of the tank. This tube may have deteriorated and come off or have a crack. You can lift the cab and reach down to the tank to pull the plug to check. good luck
Posted on Feb 06, 2011
Have a 863 Bobcat and glow plug light is flashing will running
This is caused by burnt out glow plugs, have them all tested.
Dec 15, 2016 | Cars & Trucks
How do I fix as bobcat 863 deutz running issue
diesel engine give good service provided that the fuel is clean and with no air in the system
the problem can be air in the fuel lines to the pump, blocked filters , vent problem at the tank.
diesel fuel suffers from a moss growth in the fuel tanks which blocks the filters and can cause injector tip problems
As the engine starts and runs I would change the fuel filter and bleed all the air out for a starter
you may also drain the water trap under the filter or in the water separator filter before the filter
If you see evidence of the moss ( brown slimy looking substance in the filters ) use a good quality diesel fuel conditioner to kill it off
Sep 18, 2015 | Toys
I have a bobcat 863. Sometimes it will not shut off when I turn it off. Any ideas?
Bobcat 863 863H Service Repair Manuals - YouTube
? 3:17
www.youtube.com/watch?v=Hsp-NAdM4Sg
Oct 30, 2010 - Uploaded by DiyRepairManuals
Bobcat 863 863H, Service Manual, Repair Manual.
Sep 15, 2015 | Toys
I have an 863 bobcat, I shut it off for just a few min, then when I tried to start it back up it turns over but won't start, I tried starter fluid which will start it but it will only run for a few seconds
I presuming it is a diesel bobcat, if so then your fuel solenoid has failed, you will need to replace the solenoid, it a large nut with a wire coming from it and it's located on the fuel injection pump,
Jul 24, 2014 | Cars & Trucks
Replaced engine in bobcat. It a diesel, and I know nothing about Diesel engines. There is only two wires coming from the injector pump. That's it. I bleed all the air out of the lines and it still won't...
Not sure about that particular engine - but one of the thing that needs to work, assuming the timing and compression etc are good, on a diesel engine in order for it to work is the fuel solenoid. It has to have 12v of power to it in order to let fuel pass to the engine. When power is turned off the valve shuts and stops all fuel. It is located on the injector pump and will have one hot wire when the ignition is on. You can hear and feel it click open with the ignition turned on/off.
You also need power going to you glow plugs prior to turning it over - check you are getting power to the plugs with the ignition on(power should come one for 5-15 seconds or so and then turn off), a simple test light works to test power - I have also installed an engine that had all four glow plugs that were bad, if it is a used engine I would just change these so you know. You may have power to the glow plugs, but that doesn't mean the plugs themselves are good.
If you have this working properly try using a low volume inline fuel pump before the injector pump just to get it primed and running.
Sep 20, 2013 | Isuzu Cars & Trucks
I have a bobcat 863, turns over ok, but will not start. Did not run out of fuel.
Jan 27, 2011 | Bruder Cat Skid Steer Loader
Kubota G4200H Diesel won't smoke or fire up. New gas pump,fuel filter,battery,glow plugs,new gas. Bleed lines many times. Voltage at glow plugs ( approx. 10 volts), glow lamp works. Checked 10amp fuse....
There is air in the high-pressure line from pump to injector. Ensure that there is diesel up to the pump inlet, Back off the injectors connector(s) one turn (so it's loose but not falling off). Connect a FULLY CHARGED battery and crank until diesel comes out of the loose injector connector. Whilst still cranking, tighten the injector nut. With any luck, the engine will start. You may have to repeat this several times.
The 'cheat' is to spray WD40 into the air intake after removing the filter, and crank. The engine will fire on the WD40 and run fast enough to purge the fuel line. Even when doing this, you may still need to back off the injector connector(s).
Mar 09, 2010 | Garden
What do you have to remove to get to the fuel tank on 863 bobcat
Jun 25, 2009 | Bruder Cat Skid Steer Loader
Bruder Cat Skid Steer Loader Logo
165 people viewed this question
Top Bruder Toys Experts
Colin Stickland
Colin Stickland
J.D. Browning
J.D. Browning
Are you a Bruder Toy Expert? Answer questions, earn points and help others
