Question about B&K Plumbing
On off handle on outdoor faucet very hard to turn, can I take it apart and lube??
    Problem Solver:
  • 11 Answers
If it is a brass faucet there should be a nut just where the handle goes into the tap,loosen this nut a small bit and try turn then,it should loosen it up.do not loosen this nut to much or it will cause a leak
Posted on Mar 30, 2011
Moen troubleshooting
A common problem with kitchen faucets is the o-rings that seal it become dry. Although they are somewhat lubed at the factory when installing them the installed wipes down the area to clean it wiping off the lubricate. At first the faucet works fine but over time the lack of lube causes the o-rings to become sticky. The easiest solution is to pull the faucet apart and purchase some fuacet lube and lube up the o-rings and parts and re-assemble. If for some reason you have hard water this can cause buildup of deposits and in turn dry out the o-rings and make the surfces rough which can cause the same problem you are having. Again disassemble and clen, lube reassemble.
Aug 06, 2014 | Moen Colonnade 7575CSL Single Lever...
Facet will not move left to right for both sinks hard to get it to turn
remove the handle then there is a retaining nut under that, remove the nut and as you push right to left pull up at the same time. Get smoe food grade lube and repalce as you took it a part
Best of luck
R J
Sep 05, 2011 | Moen 7840 Camerist Single-Handle Kitchen...
Price pfister classic f-wkp-533s - too hard to turn left or right, help please
You have to take it apart, clean everything, replace the upper and lower "O" rings, and lube before putting it back together. You can often get the parts for free, due to lifetime warranty.
Furthermore, you may be able to have Price Pfister send you what you need, except the lube. Go for full cartridge, if you call them. You would prefer to only take it apart once. They are happy to ship to you for free, usually.
Jul 08, 2011 | Price Pfister Pfirst Single Handle Kitchen...
I have a brita faucet filter. And the selector knob is getting harder to turn. If it gets any worse I will need to use a wrench. I wanted to try to lube up the movement if I can open up the casing. How...
I have a Brita faucet filter (model FF-100) that lately has become harder and harder to turn. I toyed with the idea of forcing the unit apart but, instead opted to lube the mechanism directly from the top, where the unit attaches to the faucet.
To this mean, you will have to 1) Detach the unit from the faucet. 2) Remove the filter. 3) Thoroughly wash the unit, inside and out, turning the knob to flush any debris that may be present. 4) Pour some drops of vegetable oil inside the mounting opening, coating the valve stem within. (Oil may pass thru the unfiltered water outlet, so choose an appropriate working space). 5) Turn the water handle (knob) to lube the valve repeatedly, until it loosens. 5.b) Optionally, you could let the oil sit for some time inside the base. 6) Rinse the unit and reinstall it on faucet (without the filter). 7) Turn knob to unfiltered position, and flush with warm/hot water. 8) Do likewise with knob set to filtered, but open faucet only slightly, to avoid over-spraying. 9) Remove base unit from faucet and repeat steps 3-9, as needed. 10) Reinstall unit with filter, as instructed by manual.
Water valves may seize due to mineral deposits. While you may be tempted to use detergents or solvents, be reminded that unless thoroughly rinsed, chemicals may corrode plastics, degrade your filter, or even wind up in your drinking water, so caveat.
Apr 04, 2011 | Microwave Ovens
Have a delta kitchen faucet single handle Addison havening a problem finding neutral have to be aggressive to get to close. what can I do to fix this only a year old I look at Manuel and wonder if the...
Well it most likely only need lubed but if you are going to take it apart to do that you may as well go with new parts. Witch ever you decide be sure to use what they call plumber lube it is made just for this purpose and will last longer then say WD-40. If you live in an are that has real hart water then plan on doing this every year or so.
Feb 11, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Moen,sgl, handle, pull out syrayer, very hard to rotate, took apart & inside trunk-very rusted and corroded, cleaned & lubed with o-ring lube. Definently helped. Should the inside of this faucet...
Hi Sharon,
Please give Moen customer service a call. If you are the original owner your faucet may still be under warranty. Regardless, you should give them a call at 1-800-BUY-MOEN to see what can be done.
Thanks
-Olivia
Dec 28, 2010 | Moen & Replacement Cartridge
Peerless faucet with a squeeky hard to turn handle.
you can get a new cartridge for it or try pulling it out and putting some faucet grease on it the cartridge should come apart put grease on everything with a black o ring and you should be good to go
Jul 29, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Handle on waterfall faucet is sticky, need to fix!!
Sounds like your on the right tract! Go to the manufactures web site to get a parts diagram and it will help you along with your project with more confidence!
Mar 17, 2009 | Dmm Kraus Glass Vessel Sink Combo w/...
Plumbing Logo
830 people viewed this question
Top B&K Plumbing Experts
Tom Chichester
Daryl Gleaton
Joe Ball
Joe Ball
Are you a B&K Plumbing Expert? Answer questions, earn points and help others
