Question about Dymo Labelmanager 220P Printer
Where is the pound/number sign? - Dymo Labelmanager 220P Printer
CANNOT FIND POUND SIGN
The pound sign is usually located above the number 3 (not on the number keysboard but above the w....e on letter keys. You have to use the shift key to get the ### key.
ABOVE THE LETTER KEYBOARD number 3 use shift #
Apr 03, 2013 | Compaq Presario 700 470024-192 Notebook
Pound sign
Press and Hold the Shift Key then hit the number 3 key. The # sign is on the 3 key, but since it is above the number 3 that means you have to press and hold the shift key.
May 16, 2012 | Computers & Internet
Acer 2300 pound sign
Where is the pound sign?
Totype the Euro sign in Windows, you press the alt key+0128. As for the Sterlingpound symbol, you can type it by pressing the alt key+0163. You can have a lookat this site where it lists ways to type currency symbols.
http://www.fonts.com/fontent/fontent_home.asp?nCo=AFMT&con=fyti_currency
Please note that you have to type the 4-digit code on thenumeric keypad (do not use the normal number keys) while holding down the Altkey.
Apr 18, 2012 | Acer Aspire 5315 Notebook
How can I write a pound sign by using a dell keyboard
The easiest way is to hold down the Alt key and type "156", then release the Alt key. You will see a British pound (£) sign appear. However, sometimes "pound" means the number sign (#), but that's mostly used in voicemail prompts.
If you use the first pound symbol a lot, you can either keep it on the clipboard, or consider remapping a key you never use (like the tilde, or ~) to type that character (see http://www.annoyances.org/exec/show/article02-022).
Hope this helps!
Apr 08, 2011 | Dell 0Y3740 Keyboard
I cannot get the qwerty keyboard on my HTC desire HD to display a pound steling sign, it only seems to have a dollar sign
The Pound Sterling sign is available. Please follow these steps:
  1. On the keyboard hit the ?123 keyboard to bring out the numbers and symbols layout.
  2. Now, hit ALT to show the alternate symbols layout. The Pound Sterling symbol is available in place of # in this layout.
Hope this helps. If so, please consider rating this solution.
-regards,
M
Mar 12, 2011 | HTC Touch HD Smartphone
I can not get the at symbole or the pound sign
hold down the shift key, and press the number 2 for pound Symbol, or 3 for at sign
Mar 06, 2010 | Computers & Internet
Can't get the pound sign over the number 3. I get
CANT GET £ SIGN, AND " HAS SWAPPED WITH @
1, HOLD THE SHIFT KEY DOWN
2, PRESS THE "WINDOWS LOGO" AND "ALT" BUTTONS TOGETHER ON THE LEFT HAND OF THE SPACE BAR ONLY. THE RIGHT HAND ONES WILL NOT WORK
3, YOU MAY HAVE TO USE THE MOUSE TO CLICK ON THE PAGE.
4, YOU WILL NOW HAVE THE "£" BACK & THE @ OR " IN THE CORRECT PLACE.
Jan 20, 2010 | Logitech Computers & Internet
Where is the sterling pound sign
To get character: £ then press down and release the Num Lock key (To make num lock on) located in the upper left part of the number pad on the right side of your keyboard so that the LED above is lit and release that key. Then hold down the Alt key and type 156 using that number pad. you will get pound sign Let me know if this helped Regards
Nov 26, 2009 | Acer 91.63X07.001 Keyboard
Pound symbol
The # (pound) sign is above the number 3 on the keyboard. Don't forget to shift before pressing on the number 3.
Hope this helps. Bud
Aug 26, 2008 | Logitech USB Internet Navigator Multimedia...
Dymo Labelmanager 220P Printer Logo
26 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
