MY SAMSUNG 36 INCH SLIM FIT TV MODEL TXS2779HX/XAA HAS NO REMOTE AND I AM UNSUCCESSFUL WHEN TRYING TO AUTO PROGRAM THE CHANNELS. IVE TRIED SWITCHING THE CABLE IN THE BACK FROM AIR TO CABLE AND TRIED CHANGING IT FROM THE TV ITSELF BUT I ONLY GET 3 CHANNELS
SOURCE: Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
Posted on Feb 04, 2009
  • 267 Answers
SOURCE: Cannot program Cable remote to control panasonic 26'' LCD
the issue is with time warner remote. contact the cable company.
Posted on Mar 06, 2009
SOURCE: Unable to tune my LG Electronics Digital TV (Model 37LC2d-ec) to receive digital channels (have tried auto and manual program). TV will only receive basic standard channels. TV bought in Uk - now livi
My LG plasma TV 50pc3d when power-on only see vertical bars. what 's going on. please help. Thank you
Posted on Jul 22, 2009
johnnydiode
  • 647 Answers
SOURCE: I have an Rca 36 inch tv, the color is messed up,
If the set wasn't dropped or physically dammaged the chances of it being the picture tube is very small.
The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
Posted on Oct 24, 2009
ladywinn
  • 5138 Answers
SOURCE: keep changing channel without any input
Most of the time it is the front contact switches Dirty clean them with contact cleaner or replace contact buttons on front panel board 29 cents each Call Mats 1-800-628-1118
Posted on Nov 19, 2009
My Sharp 55" Smart TV doesnt respond with remote
Try a different remote such as one for your bluray player to isolate if tv or remote
Nov 02, 2017 | Sharp Televison & Video
Trying to program an old one for all remote to a
One-For-All (One4All) remote codes - chose your remote first! - Go to http://www.oneforall.co.uk/support/result/?cat=8
If the remote is an old model, then it won't be programmed with a specific code for your exact model of TV. Try any of the Samsung codes, or do an Auto code search.
Sep 06, 2014 | Televison & Video
How do I get missing channels to view (all between 36 & 98 get skipped)
Does your vcr still work? I'm having same problem but vcr does not work.
Nov 13, 2011 | Televison & Video
My tv's channels are only up to ch 35, and we have cable tv connection. I cant utilize my cable connection cause my tv's only programmed up to 35. do we have a way to program it to go up to more than 35?...
I assume you have analog cable TV service and no cable box. Press MENU button on your TV remote. Go over to CHANNEL SETUP. There are four arrow buttons and a button in the middle of the arrow buttons on the TV remote control. Use these arrow buttons to go up, down, left and right. Use the button in the center to select. TV On-screen menu has Video, then Audio, then Channel Setup.
Cable can be set to ON or OFF, you want to set it ON to get cable channels.
Go down to AUTO PROGRAM and select it, press button in the center of arrow keys.
A short delay while available channels are searched so be patient. After Auto Program finishes, press MENU to exit. You can perform Auto Program whenever required.
You can also add or skip channels manually. You will discover more options in the TVs menus.
Feb 24, 2011 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
I have a samsung tv model # LNS2351W with a samsung remote control model # BN5900545A and I can not program it to the tv. I do not have the code or the users manual for the remote control, so I can't...
Have you been trying to set the program by manual (by TV buttons). If you can set it manually, aim the remote straight forward at the TV sensor and press then notice the light is responsed (blingking each pressing time). If it does not response, the problem may come from the sensor or remote. You need another good remote to isolate this problem. Alternatively, you can try this remote with another Samsung TV (if possible) to see how it works.
Jun 11, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Trying to find remote or is there another way to get all stations on this t.v without the remote
You can try to buy a samsung universal remote, buy a samsung vcr which has a tv/vcr switch, and this will let give you control of the tv and also allow you to program the channels. Because the vcr acts as a tuner.
May 11, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Emerson 20 inch flat screen tv problem
i had the same problem with a 32 inch and i kept "clicking" the channel changer on the remote to force the tv to go to another channel (that had previously been selected during the initial auto scan) --- still trying to figure out why the tv locks onto the scanning for channel
Mar 26, 2008 | Televison & Video
Old Samsung Tv Problem CT-5029v - Channel Auto Program
You might try a oneforall remote instead of a whatever :) They support a lot of old and new tv's.
Jan 15, 2008 | Televison & Video
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
