Question about Whirlpool Dryers
I cant front panel off of my LER5620KQ1 - Whirlpool Dryers
  • Whirlpool Master
  • 8,220 Answers
Cant get front panel off washer to check mcu unit as suggested.
There should be 3 t20 tork screws at bottom of kick panel. You could also take the whole back panel off to get to the motor control unit, it is located in the back lower rh corner.
Jan 26, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ler5620kq1 wont turn on. Where do i begin?
Hay william , start with the door switch if that doesn't help test the fuses for continuity good luck APPLIANCES R EN
Mar 02, 2013 | Dryers
How do i remove motor from whirlpool dryer model LER5620KQ1
http://www.applianceaid.com/images/belt-config.JPG
You will follow these instructions for replacing the belt, it will get you to the motor.
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Dec 27, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5620KQ1 - Dryer makes a clunking sound when running
It may be that one of the plastic pieces inside the trum has somthing under it. Coins of other things can get under them. You will have to tilt the top back so you can get to them. Unscrew 3 screws in each of them remove them and check them . Watch how you took it out so they can be put back just like they came out.
Take a putty knife and run it between the top and the front panel not far from the corner and push the two clips back one on each side. Raize the top up and brace it. Unhook the door switch take the two 5/16 screws out of the top of the front panel and pull the front panel toward you and lift it off the clips at the bottom. Put something under the front of the drum to hold it up while you take off the belt. On the right side reach under the drum and push the idler pully to the right and take the belt off the motor pully.Now you can take the drum and belt out. You could start the motor with the belt off and see if the motor is making the noise. Don't run too long. Now you can check the idler pully, the rollers the drum rides on in the back the felt on the front panel and the back of the drum. Also check the belt Be sure and mark how everything came off and put back just like it came off. Hope this helps
Jul 15, 2010 | Whirlpool Dryers
LER5620KQ1 Where are the fuses located.
ther are no fuse's in your whirlpool dryer.nead to know what the dryer is doing or not doing.
Nov 17, 2009 | Whirlpool LER5636P Electric Dryer
I have a whirpool dryer Mod#LER5620KQ1 the dryer makes a grinding noise when you turn the power on what can this possibly be
Check for metal shavings under the unit pull off the back cover. It seems like this can be one of a couple things. Bad main bearing, your clutch is not fully disengaging or the brake is not disengaging
Feb 18, 2009 | Dryers
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
My panasonic project tv colors are crazy cant fix convergence lin
you must adjust it by hand located in the front of the tv you must remove front panel and speaker panel,s you will se six
Jan 17, 2009 | Panasonic PT-51G44 51" Rear Projection...
Whirlpool Dryer has trouble drying (LER5620KQ1)
Hi rfairess
it sounds like the high limit thermostat is cutting out and not resetting itself.
Sep 16, 2008 | Whirlpool LER5636P Electric Dryer
Problem with microphone
most of the old motherboards dont support the audio and mic port to work both in back side(back panel header) and front side (front panel header)simultaneously...
most of the old motherboards dont support multi streaming so you cant make both the back panel header and front panel header to work at a time ie i mean you cant connect both panel header at a time ...
you can just refer to your motherboard manual for the detailed information about it ..
in your motherboard if there is any option to connect the front panel header to the motherboard other than the back panel header you can connect it to that the detailed pin information will be given in the motherboard manual ..
if you dont have the option in the motherboard to connect the front panel header seperately then you must remove the pins connected from the back panel header and you must insert the front panel header pins .
this will disable your back panel audio ,mic,linein functionalities but you will be able to connect in front panel header , this front panel header will work ..
if the motherboard is not compatible then the system assembler will leave the front panel wires not connecting to motherboard ..
like this only one panel can work at a time ,
but in the latest motherboards the multi streaming technology has been introduced so both the panels can work at a time and can play different audio on 2 different panels ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Aug 10, 2008 | ASUS P5VD2-MX SE Motherboard
Dryers Logo
137 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
