Question about Apple iPhone Smartphone
The slide does not work on my IPhone 3G, is it possible that one of the three contacts on the top are unhooked.......I just put a new battery in.
    Sergeant:
  • Apple Expert
  • 302 Answers
Maybe software problem, try going to apple site and troubleshooting
Posted on Apr 12, 2011
Dropped my iphone 3G. The error message appeared "No SIM" and I cannot make a call or receive one. I can however do everything else the iphone can do - facebook, read email, etc.
It is possible that the SIM tray came a little loose and the card lost its connection. Try taking it out and putting it back in (use a paper clip to pop out the tray on the top of the phone). If that doesn't work, then something is most likely broken and you should take it in to an Apple store for repairs.
Feb 28, 2011 | Apple iPhone 3G
I reset my iphone 3g and now its been frozen for 2 days, it only shows start-up apple logo. please help!
Do a hard reset.
  1. Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously.
  2. Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart.
  3. You may let go when you see the silver Apple logo.
  4. You have completed a hard reset successfully.
  5. Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen. This is normal.
If this does not work, put into recovery mode and restore from itunes.
Step One
Open iTunes and connect the iPhone to your Mac.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
As soon as the screen goes black release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone will look like this:
I forgot my iPhone Passcode. What can I do to unlock it?
iPhone setting:*
- Auto-Lock: 1 Minute;*
- Passcode Lock: On, require passcode immediately, after 15 min or 4 hours etc;*
- Network: Turn 3G Off
Scenario 1: Home screen is active with screen on*
1. Press power button for seconds until asked to '"slide to power off"
2. Slide to power off
3. press power button to turn on iPhone
4.*When asked to enter passcode, touch the "Cancel" key, then slide to unlock
5. bypassed passcode
Scenario 2:*
1. On the screen of being asked to enter passcode, press power button for seconds until asked to '"slide to power off"
2.*Slide to power off
4.*When asked to enter passcode, DO NOT touch any key on the screen, press power button for seconds until asked to '"slide to power off"
5. Slide to power off
6. press power button to turn on iPhone
7.*When asked to enter passcode, touch the "Cancel" key on the right bottom corner, then slide to unlock
8. bypassed passcode
Notes:
1. When Network setting changes to Enable 3G: ON, "3G" signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when 3G signal switches to "E" (Edge), passcode CAN be passed through following above steps
2. When no 3G or Edge signal, above steps don't work
Conclusion:
Seems passcode security is related to network status
Possible security hole under Edge
Jan 15, 2011 | Apple iPhone 3G
My iphone screen is enlarged?
tap twice with three fingers. It really works!
Jul 20, 2010 | Apple iPhone 3G
Iphone 3gs wont work. white flashlight screen?? please help
If iPhone doesn't appear in iTunes or you can't sync iPhone
  1. The iPhone battery might need to be recharged. For information about charging iPhone, see "Charging the Battery" in the iPhone User's Guide.
  2. If that doesn't work, disconnect other USB devices from your computer and connect iPhone to a different USB 2.0 port on your computer (not on your keyboard).
  3. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
    Note: If you enter the SIM PIN incorrectly three times, you may need to contact your carrier for a Personal Unlocking Key (PUK) to enable your SIM card again.
  4. If that doesn't work, restart your computer and reconnect iPhone to your computer.
  5. If that doesn't work, download and install (or reinstall) the latest version of iTunes.
If you can't make or receive calls, send or receive text messages, or access email or the web
  1. Check the cell signal indicator in the status bar at the top of the screen. If there are no bars, or if it says "No service," try moving to a different location. If you're indoors, try going outdoors or moving closer to a window.
  2. Check to make sure you’re in an area with network coverage. Go to your carrier's website to see network coverage areas.
  3. Make sure airplane mode isn't on. From the Home screen choose Settings, then turn Airplane Mode off.
  4. If that doesn't work, turn airplane mode on, wait 15 seconds, then turn airplane mode off again.
  5. Make sure to include an area code for every phone number in your contacts list that you use to send or receive text messages.
  6. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  7. If that doesn't work, there may be an issue with your wireless service. Call your carrier or go to your carrier's website.
  8. If that doesn't work, restore the iPhone software. See Backing up, updating, and restoring your iPhone and iPod touch software or see "Updating and Restoring iPhone Software" in the iPhone User's Guide.
MMS: Original iPhone does not support MMS. MMS is available on iPhone 3G and iPhone 3GS if it is supported by the wireless carrier. For more information, please see iPhone: System requirements for MMS.
If iPhone won't turn on, or the display freezes or doesn't respond See iPhone and iPod touch: Frozen and unresponsive for information on addressing these symptoms.
  1. iPhone OS 2.x and earlier: Press and hold the Home button until the application quits.
    iPhone OS 3.x and later: Press and hold the Sleep/Wake button until the red slider appears, then press and hold the Home button until the application quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
If iPhone continues to freeze or not respond after you reset it
  1. Reset iPhone settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but no data or media is deleted.
  2. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears restore the iPhone software. See Backing up, updating and restoring your iPhone and iPod touch software.
Jun 28, 2010 | Apple iPhone Smartphone
Is it possible to take out battery of iphone 3g? phone hang up
actually there is no batttery on the iphone to remove. The battery is hard wired to the phone board itself. However if you hold down the home key AND the power key down at the same time for about 15 seconds it resets your phone as if you removed and reinserted the battery.
May 02, 2009 | Apple iPhone Smartphone
I phone keys suddenly stopped working
Your iPhone 3G should be under Apple's manufacturer warranty. Check your user-manual for contact information. Normally, this device is not covered by insurance, so investigate your warranty through Apple. This is your best option.
Mar 13, 2009 | Apple iPhone 3G Black Smartphone
Apple iphone.where abouts do i put my sim card in the iphone?
Use the supplied tool or a straightened out paper clip to eject the sim tray in the top of the phone. There is a tiny round hole in the top of the phone that you gently push the tool(or paper clip) into to eject the sim tray. Load your sim card and slide it back in and you're done!
Good luck,
Dec 25, 2008 | Apple iPhone 3G
Cannot import contact from sim card to iphone 3G
Turn off the iPhone before inserting the sim, insert sim, turn on, import contacts. If you put the sim in the phone without restarting it for some reason it doesn't get all the contacts sometimes.
Aug 02, 2008 | Apple iPhone 3G
Apple iPhone Smartphone Logo
43 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
