Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
I have a hitachi 51f510 that will no power on. I have a feeling a fuse blew. What kind of fuse do I need and where can I get one?
  • 643 Answers
Usually not the fuse. it probably is the powersupply. fix is around 150-200 dollars.
Posted on Mar 30, 2011
Hitachi 51F510 has no picture. a RED X is visible after a pair of 'gears' in the middle of the screen appear during a long boot recovery attempt which fails ending in the red X
replace middle power supply broad that has 2 regulators, send to PTS for repair.Also check transistor mounted next to flyback transformer it maybe shorted too!
Dec 01, 2010 | Hitachi 51F510 51" Rear Projection...
We had a storm come throught and our power went out and was out for 3 days now the TV will not turn on at all. Hitachi 51F510
Its Prob been hit when the power come back one which created a surge there by killing your TV.. id be taking it to your local TV Repair man or electronics guy and getting it checked out... shouldnt be any more that around 80 dollars in quoting
Jun 14, 2009 | Hitachi 51F510 51" Rear Projection...
Power outage.. volume not as loud as before..part bad??
Yes the audio board is going bad there is a capcitor on that and it would need to be replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 21, 2009 | Hitachi 51F510 51" Rear Projection...
Hitachi 51f510 Color problem
for testing, place the green crt board on the red crt and see if the red crt lights up and the green does not. If the green does not light up then check for 200+ volts on the collector or the output transistor. if you have that kind of voltage thee then check for an open resistor. If not then make sure the transistor is not shorted
Dec 28, 2008 | Hitachi 51F510 51" Rear Projection...
No power to hitachi 51f510
Ok first of all unless you know how to use a multi meter give it up and take it to a shop
otherwise start testing voltages with a mutli mete
  • 579 Answers
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Feb 16, 2018 | Hitachi 51F510 51" Rear Projection...
Won"t stay on
Something is out of tolerance in the horizontal deflection circuit. You should try resoldering the horizontal output and driver transformer. If that doesnt help you will need to troubles shoot the deflection circuits. If you need a link to get a good quality service manual for your model let me know and I will post a link.
Mar 19, 2008 | Hitachi 51F510 51" Rear Projection...
RePost:Hitachi 51F510 W/ No Power HELP
The convergences amps are found either on the neck of the CRTs, or a seperate board directly connected to that area via cabling, depending on version of chassis...accordianman
Feb 15, 2008 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 with NO POWER
Hope Ya Fix it!
Hitachi 51f510 unit has no picture
Is set coming on and no pic or not coming on at all.
Dec 21, 2007 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
140 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
