Question about Blenders
Bravetti cordless rechargeable wine bottle opener modelWBR100B is not charging.Can iget a new battery and how do I open it jnrrivet@shaw.ca
Blender won't start
Test motor for continuity, if open circuit locate thermal fuse in windings and replace it. If not open circuit check cable for continuity, if that is ok you are likely looking at a new button control assembly.
Mar 12, 2014 | KitchenAid Kitchen Aid KSB560 5 Speed...
Weak battery
then the rechargeable battery is dead. take it to Batteries Plus to have them replace it
Jan 15, 2014 | Waring Wwo100bj Pro Wwo100pc Professional...
The unit will not turn on (after being moved)
Sounds like a bad cord. There are lots of cheap cords that fail easily these days.
Nov 07, 2013 | Sunpentown WC-1682 16 Bottle...
I believe that the motor of Braun MR 5550 CA MultiQuick Professional Handheld Blender is burned from electricity overload and i want to ask if this motor can be opened to be repaired & how this can be...
The motor in Your Braun MR 5550 CA can not rewinded like other motor in some equipmnets like motos in grinders for example.
You need a new motor but their always a question before you proceed you must ask the total cost including labour since this might be very near to the price of brand new blender. Just chect it out.
Good luck
Aug 16, 2010 | Braun MR 5550 CA MultiQuick Professional...
Does not work
Suspect that the battery has died. If still under warranty, take advantage. A new battery is otherwise fairly expensive. Good luck!
Jul 03, 2010 | Coleman 850-870 Single-Speed Blender
I want to replace the flex on a Braun MR 5550 series. I have opened the lid but the way to replace the flex is none too obvious and I don't want to prise anything in case I break it.
Hi.
We can solve this difficulty with your any Braun Product in Bangalore. Spare Parts also available.
We are the Authorized Service Center for BRAUN in Bangalore.
Our Add.
Home Tech Serivces
# 43, 1st Floor, 1st Main, 2nd Cross, 3rd Block,
Basaveshwara Nagar, Bangalore-560079
Our Contact No. is - 080-40901310
Cell.No.: +91 97404 00030
Jun 03, 2010 | Braun MR 5550 CA MultiQuick Professional...
The coleman rechargable blender not blending
Subject: Rechargeable Portable Blender Model No. 850-870
I was given one of these blenders for Christmas. I charged it through 3
cycles, used it once and the battery was dead. Charged it through another 5
charge cycles and used it once only to then have another dead battery. I
have put it through at least another 8 charge cycles, and it indicates a
DEAD battery. I have managed to blend two (2) 3/4 full pitchers in total. On
trying to start it now the green light 'flickers' quickly on and shuts down.
This is a totally useless device.
I would like to return it for a full refund, including shipping.
Dec 21, 2009 | Coleman 850-870 Single-Speed Blender
How do you take the mixer off of the wand to clean it?
YOU DO NOT NEED TO ,TO CLEAN MIX WATER AND CLEANING FLUID AND BLITZ THIS UNTILL CLEAN.
Oct 13, 2009 | Williams-Sonoma Stick Blender Handheld
Blenders Logo
139 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
