Question about Toshiba D-R400
Recording I am using a RF modulator and switcher to direct cable line into inputs in dvd-recorder and nothing is being recorded. Do I need a cable box? I am following all directions in manual.
  • 3 Answers
As long as you get a picture to your TV the same way and your on all the correct inputs and outputs you shouldn't have a problem. If the problems persists I would contact the manufacturer.
Posted on Aug 04, 2008
Digital convertor
Do you mean the Samsung DVD-VR500E? The following steps should work for most DVD recorders. (In the US, you use the AV Input with an RCA composite cable or the RF input.)
If you get a digital-to-analog converter (set top box) and your current antenna provides the OTA signal at your location, then yes you will be able to record a digital program. Connect the set top box to AV1 or AV2 (the SCART inputs). Then use the Input Sel (under PR mode) to select the input. (Alternatively, connect an RF modulator to get the signal to the coax input from the STB to the recorder.) See page 75 of the manual for the DVD-500E for details on setting the input for recording: http://downloadcenter.samsung.com/content/UM/200410/20041023105238671_00500A-VR300E-XEU-E-B.pdf . Some DVD recorders only record on the TV (coax) input. In that case, you will need a set-top box with a RF out or an RF modulator but you can still record the digital program.
A dual tuner set top box will let you watch one program and record another if both the TV and the recorder are connected to the STB. If your TV has a digital tuner, you can split the incoming antenna signal to go to the set-top box and the TV. (Then you can also watch one program and record another.)
I prefer to use a switch instead of a splitter to reduce the signal loss. However, this forces me to record the program that I am currently watching. Since most of my recording is for time-shifting, this doesn't cause me a problem.
This site, http://www.ricability-digitaltv.org.uk/pages/products/stbs/stb_search_results.asp , has a list of reviews of set-top boxes for the UK. I know in the US, it is harder to find new converter boxes. However, they frequently show up in the used market as people replace their older TVs. This may apply in your region as well.
I hope this helps.
Jun 01, 2012 | Televison & Video
Tip
RF Modulators and cable connections
RF MODULATOR HOOKUP
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
RF MODULATOR CLOSE-UP
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
http://sewelldirect.com/belkin-rf-modulator.asp
on Aug 23, 2010 | Audio Players & Recorders
How to hookup and use
A DVD recorder can hook up to any TV that has at least a set of AV inputs (you will need an RF modulator if your TV does not have AV inputs).
Just hookup your cable or antenna feed to the ant/cable input of the DVD recorder and loop it out to the RF input on the TV.
Nov 13, 2011 | Televison & Video
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
I am trying to connect a DVD player to a RCA F25216BC 25" TV - the TV only has an F type Coax connector and does not have a CH 3 or 4 switch - I put the input from the wall to the DVD player and out to the...
Your TV must be equipped with AV inputs (RCA jacks - yellow, white, red)
in order to connect this unit. If your TV does not have AV inputs, you will need a RF Modulator to connect the DVD recorder to your TV's
antenna/cable input. RF Modulators are available at
major electronics retailers such as Radio Shack or Wal-Mart and allow the 3 RCA outs from the recorder to connect to the RF modulator RCA inputs and then you can connect a coaxial cable from the modulator to the TV RF input and select channel 3 or 4 on the TV. The DVD recorder will not pass thru signals to the TV using coaxial cable as far as DVD are concerned.
Aug 22, 2010 | RCA F25216BC 25" TV
Connecting a VCR and DVD recorder to the TV
from what type of source are you doing this? if its CATV with NO BOX, i can help.
Here is a rough sketch:
use COAXIAL cable from splitter to VCR and TV and to the RF Modulator (get one at radio shack) from the RF Mod, to DVD, use RCA cables. Run RCA Cable from output DVD to Input on the TV. Run RCA cables from your VCR output to another TV Input
PLEASE RATE ME WELL if you find this useful!!!!!!!!!
Feb 27, 2009 | Panasonic DMRES20D DVD Recorder
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
Sep 27, 2008 | Televison & Video
Magnavox MWR10D6 can't record from camcorder wrong channel
OK...try this...plug your RCA cables from your camcorder into the RCA input jacks on the back of the recorder. If you have a VCR, it can be plugged into the coax input on the back of the recorder. Use the coax output and plug it into a RF modulator (about $20 at Wal Mart). Plug the RCA output cables from the recorder into the RF modulator as well (Don't ask me why, but it seems to work on mine). Connect a coax cable from the RF modulator to the TV. Make sure the TV and Recorder are both on the right channel. The RF modulator will have a channel switch to use channel 3 or 4 on the TV. Make sure the recorder is set to E1 (Rear). You can check this with the channel +/- buttons on the bottom right of the remote. Good luck.
Jan 06, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Open Questions:
Toshiba D-R400 Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
