Question about Video Game Consoles & Games
Recently i have noticed in all my ps3 games that the graphics have a ton of shadow and texture pop in could you please help as i do not want to send it back to sony or take it apart. any help would be greatly appreciated.
  • 643 Answers
Power unit up by holding down power button till you hear second beep. this will revert unit back to factory settings. make sure resolution output is set correctly for your tv.
Posted on Mar 30, 2011
Cant even run wow >.> ok, I just bought a gaming
Whats your FPS in wow? (Can be seen by hovering your mouse over the Game Menu sign (the questionmark)).
Is it only low in cities with a lot of players or is it just low overall?
Nonetheless lowering the graphics will obviously help.
Just press Escape to enter the Game Menu, and then press System, and go to the Graphics tab.
You could lower the overall graphics by taking the slider down, but I believe the most important things you should do would be:
Multisampling: 1
Shadows: Low
View Distance: Fair or Low
I would also lower Texture Filtering and Texture resolution.
The thing is I am not entirely sure how the things will change when you use the slider, but I would definitely recommend just trying to slide all the way down at first. If the settings I mentioned above are higher than I posted, I would put them down as well.
Especially Shadows can be a real FPS killer.
The View Distance has no real affect and is just for the looks.
Your PC should be able to run WoW fairly well if you adjust the settings. If you wish to increase the performance without lowering the settings I'd recommend buying some more RAM though.
Anyway, tl:dr:
Press Escape to enter the menu, click System -> Graphics -> turn the slider all the way down to Low. Make sure the shadow settings is in fact on low as well. All the settings under the Effects tab can all clear up some fps if lowered/disabled.
Sep 20, 2013 | Blizzard Entertainment World of Warcraft...
When ever i click on go to race on need for speed pro street it freeze's
Most of the games that we like is the one has a better graphics and texture. To be able to run/play a specific game, you'll need to support the hardware requirements specially Graphics Adapter (Video Card). Don't get mad when your trying to play a High Graphical Texture game, and it run so slow.
This is some solution to boost your game movement -Go to Option->Video/Graphics->Set it all to low graphical quality, or disable some graphical texture settings..
I hope it will help you..
May 21, 2011 | Computers & Internet
Glitch on ati
Many of the old games use graphic textures that are not to the power of 2. This will result in missing textures, scrambled textures, black screens and more.
Unfortunately there is nothing that can be done about this aside from making yourself an old pc or resurrecting an old one just to play them.
another suggestion is to drop the resolution down to 800x600 or 1024x768 and test there to see if this solves the issue.
As graphic cards advance they don't always hold a backwards compatibility. Its just what happens.
Feb 21, 2010 | Computers & Internet
Gigabyte gt 240 Game textures not displaying correctly
might be a power problem check the wattage of your card and the output wattage of your power supply it should be at least 20% higher than your card 450 card 650 power supply
Jan 24, 2010 | Computers & Internet
Why does it take ps3 games so long to load
Usually the game would need to cache files from the game disc to the hard drive. The files that need to be cached are generally large, graphics-related files (like textures) that can take a while to copy from the disc to the HD.
Think of it as copying an entire DVD from your drive to your computer - that's about what your PS3 is doing every time you start up a game.
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
WEIRD PS3 GRAPHIC ERROR
well your graphics card is getting hot you need to do something or you will be the next one with the red ,green and yellow lights of dead
I recommend to use a cooling device and make sure you unit has a good space to dissipate heat from the back of the unit and from the right side
Mar 12, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont play games or movies; internet still works
Make sure you blow it out before you send it in. If there are a ton of dust bunnies the service could try to void your warranty (remember do not break the seal on your PS# if so warranty is void)
Feb 05, 2009 | Sony Playstation 3 (PS3) Console
Shadowing on screen
You should get a good surge protector. Sometimes some areas have a spike in the power. That will cause interference in the TV signal coming from your PS 3. Try out different surge protectors that should solve your problem.
bimmerhp
Jan 23, 2008 | Sony Playstation 3 (PS3) Console
Ps2 on ps3 game problems
I also had this problem running PS2 games. I noticed that when it happened, my bluetooth remotes becames unpaired and could no longer be used to turn the PS3 on/off. Pressing the PS button would not interrupt the hung PS2 game (i.e., it would not give me the options to quit the game, turn the system/controller off, etc.). I talked with the Sony Playstation folks and they suggested resetting the bluetooth controllers (by poking the hole on the backside next to the screw hole). They said sometimes the bluetooth info gets honked. Just before this problem popped up, I was messing around with pairing a bluetooth headset and may have interrupted the pairing. You may have a similar situation, so try resetting your controllers. You may have to plug into the USB port if they won't re-pair after resetting (I did). Good luck!
Dec 04, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
24 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
