I just purchased and set up my Auria EQ3266e 32 inch HDTV. Everything works fine but there is a constant buzzing noise which seems to be emanating from the speakers. While the volume of the noise is constant, the noise does stop when I completely mute the speakers. Any advice on how to eliminate this noise?
  • 8 Answers
SOURCE: hook up speakers to 32 inch lcd hdtv
"Line" level audio output is available at the audio output phono jacks at the top of the rear panel, but not speaker-level output. So, you'll need an amplifier to use in conjunction with your external speakers. (An alternative would be "powered" or "amplified" speakers that have their own amplifier, but often are less satisfactory acoustically). You don't necessarily need to get a full-fledged "receiver" with multiple in's & out's... I simply used an inexpensive stereo amplifier.
Connect the "Audio L - R" jacks on the rear of the set to the "line" or "aux" inputs on your chosen amplifier and speakers. If you go into the set's Menu - Option - Output Select and set it to "Variable", the internal speakers will be disabled, and you can control the volume (and muting) of the audio sent to the amplifier, and still have "armchair" control of the volume as before... but now with better stereo!
Posted on May 22, 2009
  • 8 Answers
SOURCE: buzing sound
Usually this is a defective main board, if it's under warranty it's an easy onsite fix. Usually takes less than half an hour.
Posted on Aug 22, 2009
SOURCE: Buzzing noise coming from my speakers....
I just did this last week, i had the same problem all you have to do is grab some speaker wire and wrap it arround the RCA's(around the metal or gold piece outside the RCA) that go to your voice AMP and then ground the speaker wire(the one you wraped the rca's with). this will work. NO Noise filter will work cus I tried it
Posted on Sep 06, 2009
  • 12 Answers
SOURCE: No Sound on Samsung HDTV? But there is a picture...?
have you tried to umplugging the tv and let it sit for a little while. I would unplug the tv like before you go to bed and plug it back in in the morning and try it
Posted on Nov 18, 2009
Testimonial: "Well, I unplugged it for several minutes, and that was enough... thank you very much!"
budmrtn
  • 11361 Answers
SOURCE: loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Dec 22, 2009
Buzzing sound in my car speaker after installing stereo with install kit
That is alternator noise install a 12 volt noise filter inline with the power to the deck.
Jun 28, 2017 | XO Vision XD103 FM and MP3 Stereo Receiver...
Danfoss 103 timer is making a constant buzzing noise!!...everything's works fine but I want to stop this buzzing noise. Any actions I should take or advice would be much appreciated. Thanks.
How much wattage is going through the timer and what is its rated load max? try unplugging whatever is plugged into it and see if it stops but if you exceeded the max load might be damage to the internals which can cause that buzz.
Feb 05, 2013 | Hardware & Accessories
I have a 32 inch vizio with internet apps. every time i turn off the tv a humming/buzzing noise that won't go away unless i unplug the power adapter! When it's on it works just fine.
Tv power supply board have input and output high voltages issues.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 27, 2011 | Vizio L32 32 in. LCD HDTV
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My toshiba makes a buzzing noise when the colour
you will need a power board the laninat in the power transformer is vibrating causing your buzz wine
Nov 02, 2009 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Constant buzzing noise
is the buzzing happening with the volume off?
Oct 10, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
