Question about Whirlpool Refrigerators
Food is freezing on the reg side of the fridge. The knob is turned to #3 setting.
  • Whirlpool Master
  • 43,501 Answers
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Apr 01, 2011
My LG 693 LTR fridge freezer model no P247STSL is freezing the food in the fridge and building up ice in the fridge on the left side of the drawers on the wall on the side of the freezer, sometimes the fan...
The reason why fan is making loud noise is because of the ice built up on the coil because of freezing.
You can check your drain line to see if it's clogged and clean it out .
There are several video on you tube showing you how to clean drain line.
Hope this help
Jun 02, 2017 | GE PSS25SGN Side by Side Refrigerator
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
When The Temperature Setting Is On 1 The Food In The Freezer Dosent Stay Completely Frozen But When i move it up to setting 2 it freezes things in the fridge...and theres water leaking out the back
Do you just adjust the fresh food side or do you adjust the freezer setting too? Post the model # . does the unit have knobs or buttons for setting temp? Does food freeze in one particular part of the fresh food side or evenly throughout?
Apr 15, 2011 | Refrigerators
Fridge is freezing
There are two things you need to make sure before you declare the fridge at fault. Firstly, make sure that fridge isn't overloaded with items and that any air vents aren't blocked. Give it room to circulate the inside air. That helps it to cool evenly/at all. Next, find the thermostat. This will most likely be inside the top of the door frame when you open the door on newer fridges, or somewhere along the back or side walls. There'll be a setting for the freezer, and a setting for the fridge. The knob might use letters, numbers, or an arrow that says COLDER. Set the knob to slightly warmer, then leave the fridge alone for 24 hours. I highly suggest putting a suitable-type thermometer in the fridge and adjust the temp until it's around 34-38 degrees F. Do NOT allow the fridge to become warmer than 40 degrees. Between 40 and 140 degrees F is the "danger zone" where microbes thrive in food and are much more likely to cause food poisoning. You must never let food sit in the danger zone for more than 4 hours.
If cleaning the fridge and adjusting the thermostat don't work, you'll definitely want to have a refrigeration professional take a look at the fridge. It may as simple as adding coolant or "freon".
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Westinghouse WSE6100SA fridge in side by side fridge freezer free
the thermostat has broken down and needs to be replaced,, normaly when they brake down they just stay in the closed poshion so the fridge freezes up get a new one fitted and all will be well
Feb 19, 2010 | Refrigerators
Water not working, ice is. fridge is set at 2.stuff freezing
i have this exact same problem. Started about 3 months ago with the crisper and now the water. when I turn the fridge off after a few hours the water works again. I'm calling the repair person tomorrow
Jan 30, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Food in fridge keeps freezing over. Also when turn temperature control knob cannot hear compressor kick in.
turn down setting in fridge gradually , it will take at least 24 hours to control the temp it wont happen instantly , when you turn down the setting wait and check the next day
Jan 16, 2010 | Fisher and Paykel Refrigerators
Fridge and freezer same temp.
First of all, there is only one thing that cools in a fridge and that is the freezer. The fresh food section is cooled by air forced into it from the freezer.
  • You ice maker will not work if the temp inside the freezer is above 5 degrees. It has a thermostat inside it that enables it.
  • The knob that turns the fridge off and on is the thermostat for the freezer.
  • The other knob opens and closes a damper between the freezer and fresh food section.
  • There is a fan that should be running that pulls air from the freezer into the fresh food section.
(The factory does make the discription of the knobs confussing)
Now. turn one of the knobs all the way one way and then the next. If it turns the compressor off, it's the thermostat. If it does not, try the other knob. Once you find the thermostat, set it in the middle of the scale. Now place the other knob the same. Check and see if you can either feel or hear the inside fan running. If so lets go to the back. This is where your compressor is. It is under the fridge and also has a fan that blows on it. You will need to remove the back bottom panel. See if you can tell if the fan is running. Also notice if the fan is blowing into a set if coils. You should also be able to fill the compressor, if it's hot, it's running. If these two are running, and you didn't see a coil at the fan. Take the front kick panel off the fridge and clean the coil that's under the fridge. If it's dirty, give the fridge a couple hours and see if it cools down. If so, this was your problem. If both knobs are set mid scale, both fans are running, the compressor is also running and the coils are clean. You most likely have a bad timer, compressor or thermostat. This is all that's left.
Please rate solution
Sep 16, 2009 | Amana ASD2326HE Side by Side Refrigerator
Which way do you turn the temp. knob
loper the number on the thermostat dial, warmer the fridge. higher the number, colder the fridge. normal setting is about "3"
Apr 19, 2007 | Magic Chef MCBR170 Compact Refrigerator
Refrigerators Logo
57 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
