Question about SuperMicro H8DGUF Motherboard extended ATX AMD SR5670SP5100 Socket G34 SATA300 (RAID) (MBDH8DGUFO)
We have a supermicro server with the H8DGU-F mother board Bios h8dguc-f 12/10/10 Rev 1.1 2 sticks of 2 gb kinsgton DDR3 1333 set up as a raid 5 using a highpoint 4channel PCI-e Raid Controller RocketRAID 2300 with both memory sticks in we get the ACPI is not fully compliant and system STOPs With one of the 2gb sticks out system installed windows 1008R and we sign into the domain setup passwords/id. but when we up the the second stick and system is rebooted it may or maynot and usually not STOPS at the blue error screen any ideas?
The Machine
  • 788 Answers
SOURCE: acpi complaint - reg
Reset you BIOS to it's default. Hit Del/F1/F2/F10 or whatever key the machine prompts you when it first boots to get into system setup. Then pole around to find a restore to defaults option.
Or you may in fact have to upgrade the BIOS, what kind of system or motherboard to you have?
Posted on Jan 17, 2008
  • 287 Answers
I have located some info on this board. it was released as a "Medion" board
there is some BIOS and driver stuff available HERE
http://www.medionusa.com/ and select customer care.. you need the exat model no or the serial no of the PC to continue though.
Also http://www.treiber.de/ may me of assistance as I think they are the real manufacturer but as I cannot read German I cant really be sure. they have the link to Medion on their webpage...
HIH and please post back results
Posted on Jul 18, 2008
SOURCE: Need help on SuperMicro SuperServer 7043M-6!!
ok, all you have to do is reset CMOS. the same thing happened to me once I tried to install windows on my supermicro board. What you have to do is load the bootable CD that came with the board and follow the instructions in your book.
What happens is that windows does not have the drivers for the supermicro RAID and SATA components. The board will recognize these on it's own until you go to install windows improperly. Windows does not have the drivers for those, realizes it, and says "Windows has stopped to prevent damage" but it does it anyway. Just clear CMOS, read the book with the board on how to install an OS, and try again.
Clearing CMOS: This can be done by taking out the 3.5v watch battery you see on the board for about 5 minutes. Another and riskier way is to clear CMOS by shorting the pads. On a diagram of your board, you should see CMOS Clear. Find those two pads on you board in that general area from the diagram. You'll know you've found it because the board has CMOS Clear printed near them. Just touch them with a screwdriver for 5-10 seconds. CMOS should be clear and ready to start new.
WARNING! Be careful when clearing CMOS with the pads, if you stick the screwdriver in the wrong place, you could damage your board. Be sure to unplug your power supply before working on your machine (I'm sure you know this.) and be sure to get the correct drivers for windows this time! Oh, and rechange any settings you changed in CMOS since it has been reset to the factory defaults.
Posted on Dec 03, 2008
  • 67 Answers
SOURCE: The acpi bios in this system is not fully compliant
did you try updating bios
Posted on Dec 22, 2008
map9966
  • 2351 Answers
SOURCE: ACPI is not a compliant
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
http://support.microsoft.com/kb/314830
Cheers
Mike
Posted on Jun 01, 2009
Live chat fixya
So that's the motherboard model number, and it only accepts 2 SATA devices. I will assume there is a RAID card on the machine as well. Being a supermicro, it's almost certainly a mid-range Adaptec card. You'd have to check the card to make sure it accepts it, but it should handle it with no issue.
However, before you go all 3TB disk on it, remember that the rebuild time on disks that size tend to be huge and should you get a second failure in the array during the rebuild you'll lose data. The important here is to format RAID 6, or 1+0 and keep a hot spare so that you can mitigate those risks. Also try to get the same disk from multiple vendors to get different manufacturing lots. Ensure they are all running the same firmware rev.
Sep 22, 2013 | SuperMicro Computers & Internet
X8DTL-3F ESXI RAID
ESXi is definitely supported on Supermicro's X8DTL motherboard. However, software RAID is not supported.
If you are having issues with a specific hardware RAID card, check the compatibility list for your card.
VMware Compatibility Guide
Jul 02, 2012 | SuperMicro X8DTL-3F Server Board -...
We just purchased Supermicro 1026T-URF SuperServer: X8DTU-F motherboard. Added Intel X25-E Extreme (Ephraim) SSDSA2SH032G1 2.5" 32GB SATA SSD drive and attached a SAS storage via Areca...
Make sure the DVD is plugged into the left most SATA connector on the motherboard. ( I-SATA0 )
Make sure SATA1 is set to "Compatability" in the BIOS.
Do not use "Enhanced" for SATA1.
Make sure the Primary IDE setting is CD/DVD in the BIOS.
Do not use "Auto"
On the USB problem, Make sure Legacy USB is disabled in the BIOS.
WARNING! The default is, Legacy USB " Enabled".
Apr 01, 2011 | SUPERMICRO COMPUTER Supermicro X8DTU-F...
I have ML350 G3 Server SA 532 and 2 HDD SCSI, W2K. I want intall RAID 1 Can I help me???
unable to understand your question.
If you want to configure raid 1 and install OS freshly then follow these steps.
1) make ready all the required h/w.
2) Swith on the server.
3) when post starts reading SA532 controller press F8 button .
4) you will enter into Raid card bios.
5) select View to know any existing logical drive.
6) select Create logical drive,select both hdd's by pressing space bar.
7) press F8 to confirm changes,save and exit.
8) Enter into bios and set the boot controller order smart array controller as 1st.
9) press escape button and restart the server.
10) boot with cdrom and proceed for os installation.
6)
Jan 19, 2011 | HP Compaq ProLiant ML350 G3 Server
I was assembled a PC to edited video HD. This PC comprises: mothercard Supermicro X8DAH+, 24 GB of RAM, 2 X Xeon 5620, 1 X SSD OCZ Agility 2 3 X HDD Hitachi 1TB CD/DVD/BR LITEON ihbs112 GPU...
Remove the 3 hard drives and install Windows on the SSD. After successfully installing Windows you can add the hard drives and create your raid array later. Or even better, pick up a cheap RAID card so your CPU doesn't have to do all of the RAID controller work.
Dec 15, 2010 | SuperMicro X8DAH+F motherboard Intel 5520...
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
Wont boot says array controller wont start and no bios dell power edge 2500 server
Sounds like the RAID controller has failed. I would replace this first as RAID controllers are less expensive than replacing the system board, or the server as a whole.
Suggested: PERC 5i (RAID 0/1/5) or PERC 5iR (RAID 1 or 0 only)
Jan 03, 2010 | Dell PowerEdge 2500 Server
Dell 3000
Though I could not find it I am guessing that you mother board BIOS was programmed to read no more that 1.5 GB Ram. It originally only came with 256k of ram.
You might want to read page 54 of your manual.  http://support.dell.com/support/edocs/systems/dim3000/en/index.htm#printed_documentation
Jan 06, 2009 | Dell Dimension 3000 PC Desktop
Feb 06, 2008 | SuperMicro SuperServer 7043M-6
SuperMicro H8DGUF Motherboard extended ATX AMD SR5670SP5100 Socket G34 SATA300 (RAID) (MBDH8DGUFO) Logo
162 people viewed this question
Top SuperMicro Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Tony
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
