Question about Maxtor Hard Drive
Hello i plugged in my laptop cable in my external hard drive by mistake and when i put the correct power lead the ehd makes a noise but not as before,i tried to open it to see if anything was burned but it looks ok. Is it broken or can i repair it somehow and recover the data??
    Problem Solver:
  • 7 Answers
You will have burnt out the electric side of the external drive and possibley damaged the harddrive.
Your best soultion would be to buy a hdd caddy and remove the hardrive from the enclosure it is in and place it into the new caddy, plug it into the pc and see if you can still use it and see and recover your files.
If the above does not work. There is a chance you have damaged the drive as well and depending on you level of computer know how you can rebuild a hdd i came give you full details but it is a very complex process and has to be done in a sealed enviroment which is dust free.
Posted on Apr 25, 2011
Hi...my wd hard drive was dropped and now makes a static ticking noise when plugged in and wont work
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your hard drive using a high powered suction vacuum cleaner or a fine air blower from a air compressor making sure there is no MOISTURE in the air lines then give the hard drive a firm tap on the side to free it up
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 18, 2011 | Western Digital MY BOOK HOME 1TB EXT...
Ihave a 1.5tb that I have not used in months. I plugged it in and all I get is beeping noises. The green light is on in front and the unit feels warm to the touch. Any solutions?
the beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 18, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My laptop did will not recognise my maxtor basics external harddrive
hope this helps
Apr 16, 2011 | Computers & Internet
I am trying to do a back-up from my computer but the external hard drive does not appear on "my computer". when the external drive is connected to the external usb drives it makes a noise.
The cable coming off the hard drive should have two usb plugs. Make sure both are plugged into the computer so that the drive is getting enough power. If it's a laptop you are plugged into the same thing applies but also make sure that the AC Adapter is plugged into the laptop when you plug the external drive into the USB ports. Sometimes it won't power the drive if it's running off battery power.
Of course it could be a problem with the Hard Drive within the enclosure if it is a constant clicking. But it sounds like it could just be the USB port not powering the drive up.
You could try on another pc as well.
Jan 21, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
Seagate 3.5' external hard drive power cord 's
Did you eHD recently fall from high place or some sort of like that?? Did your eHD is still under warantty?? If yes, i suggest u to send them back the eHD... They will repair and try to recover almost all the data inside your eHD...
Feb 28, 2010 | Computers & Internet
Hard disk not detected sometimes
I can think of 3 possible causes to your problem:
1. Faulty cable - try replacing the cable by borrowing a working cable from a friend. If this solves the problem then you need to buy a new cable
2. Lack of power - some USB drives especially those for high capacity drives require extra power aside from that provided by USB. If you do not have a separate power leading to your drive, check if there is a separate power slot and run a cable from it to your outlet/USB slot. Just make sure that the voltage levels are correct.
3. USB Slot - some laptops' USB slots do not produce power enough to drive a hard disk. Other devices may work (e.g. keyboards, mouse) but not hard drives. Try to use another slot in your laptop. If this works, remember to use the same slot next time.
Hope this helps.
NOTE: Please rate our help to keep this free service online
Jan 08, 2010 | Western Digital External USB 2.0 80 GB...
Power to 1T EHD not going through
yay, I plugged it back into my computer at home and it worked... might have not been enough power or the USB connection wasn't strong enough. anyway, happy happy happy...but have learnt a big lesson...BACK IT UP ON DVD as well.
Mar 26, 2009 | Western Digital My Book Essential 1TB...
External hard drive wrong power supply was plugged in
The power circuits in the external hard drive enclosure may have burnt out or the fuse may have blown. Its unlikely your hard-disk is itself damaged.
You may remove the actual hard-disk from the enclosure and put it in another and access the data.
All the best!
Jan 29, 2009 | Computers & Internet
PS3 Does not register external hard drive
The E.H.D. might not be formated correctly. The Playstation 3 will not read any disc or hard disc if it is formatted under NTSC. It must be formatted under FAT or FAT32 ( can't remember exactly). You would need to format the E.H.D. with windows and check to see if you can format it for FAT32 if not then you need a formatting software (Max Drive or some other). Mine works great.
Good luck
Ken
Sep 29, 2008 | Sony Playstation 3 (PS3) Console
External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
May 11, 2008 | Western Digital My Book Home Edition 500...
Maxtor Hard Drive Logo
44 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
