Question about Whirlpool GEW9250 Electric Dryer
Whirlpool old dryer
My dryer is not heating up and it takes like 3 times drying two pieces o clothes will you help me with this problem
    Genius:
  • 2,920 Answers
The heating element needs to be replaced its in the back of the dryer
Posted on Aug 16, 2008
My whirlpool electric dryer WED5560SQ0 takes an extremely long time to dry, almost like it steams
it defne sounds like one or more of your heating elements is faulty , try a simple continuity test on them
Feb 12, 2012 | Whirlpool Dryers
Dryer runs well but will not heat up and dry
You need to clean your dryer vent and make sure there are no obstructions.
Jan 02, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer heats up but doesn't dry clothes take 3 hours after restarting 3 times to dry 3 articles of clothing.
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
Oct 15, 2009 | Whirlpool LER4634J Electric Dryer
My Dryer not that old, takes all day to dry a small load.
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 31, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer....heats
You could have heating element going bad, or a plugged dryer vent. Start with dryer vent, make sure all lint is out of it, all the way through it, even if it goes to the roof, or out the wall. Also vacuum out back of dryer and inside vent tube. This should help with problem. If not then replace heating element its getting weak.
Jul 19, 2009 | Whirlpool LER4634J Electric Dryer
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
2. Thermostat
3. Heating element
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Clothes won't dry
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 01, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool Gas Dryer takes 2 or 3 cycles to dry clothes
did you check ALL lines..in and out for clogs!?
Mar 15, 2009 | Dryers
Dryer will not heat until after about 2-3 loads
I am online looking for an answer similar---our dryer doesn't heat....air comes out lukewarm and will not dry after 2-3 cycles.
Jan 02, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
