Question about Canon Cameras
I bought a canon sd 750 powershot digital camera around 4 months ago and now the lcd screen flickers and does not come on sometimes and when it does it is dull and flickers can some one help me as i bought it newly refurbished and i cannot contact the supplier. Thanks. Kind regards Richie.
    Master:
    Sergeant:
  • 398 Answers
Go to canon USA, and check on warranty. If it is a true factory refurbished it should have the standard warranty.
Posted on Aug 04, 2008
SOURCE:
Hi my Canon Powershot SD 750 LCD screen stays black when taking pictures, you can't view them either. The only thing that shows up on the screen is the menu functions, you can look through everything...
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, astuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 05, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon powershot a495 has a problem. it always shows low battery and turns off. i have changed to new batteries three times but the same problem. i bought 3 months ago. help please thanks
my canon powershot a495 has a problem.
Apr 18, 2011 | Canon PowerShot A495 Digital Camera
Dropped my Canon SD 750, will turn on and lens will move, but the display screen is black & won't show anything- is it unfixable?
Is the screen cracked from the impact of being dropped? It may be worth it to have the LCD screen replaced or just checked in case the LCD ribbon came loose during impact. I would probably contact the guys in the link I posted above and have them check it out. This issue is most definitely fixable though!
Sep 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cannon SD 750 - when i try to take a picture a black screen appe
Think that you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Jul 29, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Black screen problem with Canon PowerShot SD 750
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
May 27, 2009 | Canon PowerShot A550 Digital Camera
Memory card error
I assume that you know that there is a tiny tiny on-off switch on the edge of each SD card. If they are locked in the off position....
Apr 29, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
White LCD screen
The LCD connection may be loose or the LCD itself broken. You may need to have a service centre replace the LCD unit.
Apr 13, 2009 | Canon PowerShot SX10 IS Digital Camera
Looking for a free manual for a canon ixus 750 for free download
The model # helps, you posted this under sd 550 and put ixus 750,
canon does not show a ixus 750.
This is there website, look around for your model.
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Apr 07, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Lens trouble canon powershot sd 550
check here...http://www.fixya.com/support/t102982-e_18_problem
Oct 02, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Cameras Logo
51 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
