Numbers are on the screen blinking and i cant control the temperature
    Champion:
  • 232 Answers
TRY TO RESTORE YOUR COMPUTER TO AN EARLIER POINT
Posted on Aug 04, 2008
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Tv power light(red) continuously blinks. and clicks off
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 31, 2013 | Televison & Video
Red diode blink black screen
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 09, 2013 | Samsung Televison & Video
I have a plasma lg32lb9d.when i plug it in the red light turns on next to the power button but when i press it it starts flashing green then it stops flashing and stays on but the screen doesnt turn on.i...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 19, 2017 | LG 32LB9D TV
Cant make the remote connect to the TV. Got it set up to the TV. Wont change channels and no guide will come up.
Hi there, Tommy Faust with DISH Network Executive Offices here. It sounds like the remote is not programmed to the receiver. I have included steps below to get that programmed.
1. Go to the System Information screen and check the number under Remote Address.
2. Hold SAT until all buttons on top of the remote light up.
3. Let go and while SAT is blinking enter a number between 1-15 on the number pad and press #
4. Press record 3 times and see if the number changed.
Sep 21, 2010 | DISH Network IR Remote Control
What does it mean when the temperature number on the climate control blinks?
it means that a fault exists in the controls or.sensors of the automatic air temp control, the dealer can run a self test and see what the problem is.
Nov 06, 2009 | 1994 Oldsmobile Ninety Eight
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
2005 pathfuinder - climate control display blinks
Could be a number of things, usually a blinking screen indicates that the climate control module is defective. But not always, If one of the vent doors jammed of a solenoid for one of the doors malfunctioned It would cause the screen to flash.
Apr 26, 2009 | 2005 Nissan Pathfinder
Samsung model rs2533sw control panel not coming on
http://www.fixya.com/support/t1914675-control_panel_not_working_samsung
Nov 30, 2017 | Refrigerators
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
