Question about 3Com SuperStack 3 4924 Networking Switch
3COM network switch access problem
The previous operator of this switch left the company, did not write down the user and password to access this 4924 switch. How can one recover from this problem and access this switch?
Tom
You Could check to see if it has a passowrd and username as 3com or user as username or password thats wat mine is and i forget my pass
Posted on Aug 05, 2008
Decrypt 3com password
Use a brute force password solver or at best do a reset
Dec 05, 2016 | 3Com Computers & Internet
Recovery password 3com wx2200
Try this http://www.fixya.com/support/r11153882-general_routers_reseting
Jan 14, 2014 | 3Com WX2200 (3CRWX220095A-US) Wireless LAN...
Forgotten password for wifi network
Which operating system ??
Your wireless Internet password is the encrypted security pass phrase that was set up when you installed your wireless router.
Your router allows you to access the Internet.
If you have access to more than one wireless network, you may need to remember multiple passwords.
If you happen to forget one password, you have two options: reset your password or locate the current password.
Windows 7 allows you to view the security characters of all your wireless network passwords.
Click the "Wi-Fi" network icon located on the Window's taskbar.
Right-click the name of your network's "SSID" name and select "Properties" from the drop-down menu.
Click the "Security Tab." The network security key is now visible but unreadable.
Click the "Show Characters" check box and this will reveal your wireless password.
http://www.thewindowsplanet.com/939/how-to-recover-wi-fi-network-key-in-windows-7.htm
or
Reset My WiFi Password
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser.
Enter the default address of your router.
The default address is listed in your user manual or on the product website.
Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings. Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
How To Reset Your Router's Password
http://www.lostintechnology.com/how-to/how-to-reset-your-routers-password
Jan 06, 2014 | Computers & Internet
I forgot ip address and password and want to factory reset
Connect the console cable, open a connection to the serial port via a utility such as PuTTY, and do the following:
1) Enter the user name "recover" and password "recover" to place your unit in password recovery mode. The unit will remain in password recovery mode for 30 seconds max.
2) Perform a hard reset by removing power, waiting 10 seconds, and then re-applying power.
3) Once the switch has rebooted, enter a new password for the "admin" user account.
4) Enter enable to leave password recovery enabled, or enter disable to turn it off. You are now logged in as the default "admin" user.
Note: If password recovery has been disabled, the only way to recover access is to return the switch to 3com.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
Hello sir..im have the switch model 4924 24 port....i want to reset but dont know how to do that....can u help me to settle this prob sir...i want to make this switch like new means the function like new...
Connect some text-based terminal emulator such as Hyperterm, telnet,VT100, etc to the serial port. Configure the emilator
to19200 Baud 8 plus none.
Switch the 4924 on and login using the user "recover" (without quotes) and password "recover" (also without quotes.
The switch will go into recovery mode. It will display a count-down starting at 30 seconds. If you power thye switch off before the count is up, the default password for the main administration account "admin" will be cleared.
After a few seconds, power the switch on and set a new admin password.
After loigging in again, take the option "GettingStarted". Configure the ip settings (best to use a static address) and eventually you will get to the "Initialize" option. Enter yes, and after reboot it will be at factory except for its ip address.
Jun 01, 2011 | 3Com SuperStack 3 4924 24-Port Gigabit...
I have forgotten my network key
access the router from the browser. take a look at the user manual and go to wireless area and get your password. this will walk you thru accessing the router as well
http://support.3com.com/infodeli/tools/wireless/3crwer10075/3CRWER100-75_User-Guide.pdf
Mar 24, 2011 | 3Com OfficeConnect Wireless Router
Default password is incorrect or reset doesn't work
The default ip is 192.168.1.1
default user-name and password for the 5 models of 3com are as follows.:
1.
3com default ip: 192.168.1.1
username: n/a
password: admin
or
2.
user-name: adminttd
password: adminttd
or
3com default ip 192.168.1.1
user-name: admin
password: n/a
or
user-name: n/a
password: PASSWORD
OR
5
user-name: root
password: !root
ok try
this
Note that at time you will need to set your local ip of your pc from which you are acess the device to the same range...
That is for example 192.168.1.10
Good luck
uttam
Feb 26, 2010 | 3Com 2816-SFP Plus (3c16485-us) 16x1000...
How do I connect to 3com officeconnect dual speed switch 8 plus
on a mac u have to go to finder, applications, uttility, network utility and in there under the info tab there is a drop down. in that drop down you have to choose network interface (en1) AND IT GIVES YOU THE IP ADDRESS
Jun 04, 2009 | 3Com OfficeConnect Dual Speed 16 Plus...
Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
Mar 05, 2009 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
3Com 3824
Download free version of HyperTerminal for Vista : ftp://ftp.hilgraeve.com/htpe/htpe63.exe
Make a new connection :
connect using COM1 (depends of your configuration)
19 200 bits/sec
8 data bits
No parity
1 stop bit
No control of flux
And push enter twice to display a "Login:" prompt.
Connect using default user/passwords : http://support.3com.com/infodeli/tools/switches/ss3/management/ug/setup.htm#13131
Regards,
AstroMan
Jan 14, 2008 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
3Com SuperStack 3 4924 Networking Switch Logo
903 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
