Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
My AC is not cooling the air
My AC was flashin FE, so I read my manual and emptied my tank, but it is still not blowing cool air
  • Anonymous Sep 19, 2008
    Had an ft blinking & emptied the tank & cleaned the filter. Put the cover back on, etc. Is running now, but not blowing cool air.
  • Anonymous Mar 28, 2009
    when tank got full i drained it now it does not blow cold air just room temp. I unpluged it for 5 minutes and turned it on to max cool but does the same thing comp is running.
  • 750 Answers
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, it is not blowing cool air after you emptied the tank.
Turn the unit off and unplug it for 5 minutes.............
Then back in with the plug and turn it on max cool.
Give it 5 or 10 minutes to get cold, and we will see if this procedure has reset the system.
Then get back to me and let me know it's working!
How old is the unit?
Please remember to leave a rating before you go!
Thank you Huuum
Posted on Sep 29, 2008
    New Friend:
It didn't work it goes cold for about 3 minutes than give a rumbling sound an blows warm air
Posted on Aug 13, 2015
Just bought used portable ac. it blows great cold air then blows warm air for a while then back to cool andcold... is this normal? if not hwo to fix?
Yes it's normal in most cases. There should be a knob to turn so it cycles on more often. If it's not a window unit, & is a free-standing unit, you might have to empty a water pan or tank on it. As condensation collects on the cooling coils, it collects in a container near the bottom. If it's full of water, it will cycle the cooling off until you empty the water container or some of the water in it evaporates.
Jul 08, 2015 | DeLonghi Heating & Cooling
Condensate problem with portable AC
It's doing what it is supposed to do. put a permanent drain on it.
Nov 18, 2017 | Almo Heating & Cooling
Haier esa410ke manual
my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
I have a Matrix dehumidifier which says it`s a Refridgerant,does it means it`s like an airconditioner?If so how do you use it nothing on the manual to illustrate & do you fill it with water...
Dehumidifiers are small Air Conditioners that blow their cool air over the condensing coil rather than into the room. They work exactly like an AC unit except they don't blow their warm air outside. If you can install an AC unit of about the same size, you can dehumidify AND cool for the same energy costs. All you should need to do is plug it in and run a hose to a drain or keep its condensate tank emptied. By the way, the water it produces is free of minerals and some people say its good to wash your hair with. (?)
Apr 01, 2011 | Heating & Cooling
2004 santa fe AC only blows cold for a minute or two, then continues to blow air, but no longer cold....tried refrigerant, but didn't solve the problem....Any ideas?
I would first make sure you didnt over fill the system, you may have to exvacuate the system and then recharge it, then watch to make sure the cooling fan is colling condensor, if fan is not working that may be the problem,next if fan is working i would check for power at clutch, this will tell you if the clutch is bad or if its loosing power to clutch,you should have gauge to watch the hi and low side preasure readings.
May 12, 2010 | 2004 Hyundai Santa Fe
Ac compressor does not turn on when car has been sitting & it's hot outside. Works fine in the morning.
either the freon charge is about 1/3 low, or the expansion valve needs to be replaced. Freon is getting into the evaporator, but not in great enough volume to cool the air unless it is coming in cool to start with. check your ac charge, and if it is full, then have it emptied, change out the expansion valve, and recharge it
May 14, 2009 | 2002 Jaguar S-Type
Stand alone AC blows cool air but does not cool the room
send tank capacity.model mail me mintex007@yahoo.com
Oct 09, 2007 | Heating & Cooling
Heating & Cooling Logo
1,022 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
