Question about Kirby Vacuums
How do i put a new belt in kirby vacuum ultimate G
    Novelist:
  • 97 Answers
You'll want to rotate the front plastic piece 270 degrees until the red triangle on the plastic piece lines up with the red triangle on the top of the nozzle. Then, rotate the nozzle release (located under the headlight assembly) until the nozzle can pull free of the main vacuum body.
Rotate the front plastic piece back to its original position and flip the nozzle upside down. There will be two clips which will rotate to release the baseplate. After removing the baseplate you should be able to remove the brushroll and take the belt off.
Put the new belt onto the brushroll, and replace the brushroll in the nozzle, making sure that the colored dot on each bearing end is the same on both sides to ensure that the brushroll sits level. then rotate the plastic front cover again, watching to make sure that the hook inside grabs the belt and pulls it upward.
Replace the baseplate, then turn the nozzle back upright and replace it on the front of the vacuum by setting it onto the axle on the front of the machine and then tilting the top of the nozzle back into place and turning the nozzle release back to lock the nozzle into place.
Rotate the plastic front piece back to its original position, and your belt should be fully installed.
-R
Posted on Aug 04, 2008
How to put together Kirby ultimate G vacuum cleaner the rubber part in the inside.
We actually recorded a very informative video repair with this exact problem. This will walk you through step by step on how to replace the belt (the rubber part) on all Kirby Generation uprights (including your Ultimate G). Also it will show you how to do basic maintenance on the brush while you have it out.
If you haven't already purchased a new belt, here's a direct link to the belt your vacuum uses on our website:
Kirby Generation Vacuum Cleaner Belt. Kirby Part # 301291A
If this video is helpful to you, please help other Fixya users that have the same problem find this video by rating the repair helpful. You can do this by clicking on the 4 Thumbs Up Icons in the top right hand corner. If you have any questions, please don't hesitate to ask.
Here's the video:
Chris J.
GoVacuum
Apr 10, 2010 | Kirby Ultimate G Bagged Upright Vacuum
My belt broke on my kirby G-5. I havent put a belt on it in 10 years. I having problems getting it on.Can u tell me the right way? Thank you.
Greetings,
I recorded a video repair of replacing the belt for the Kirby generation vacuum cleaner. The following video will walk you through step by step on how to replace your Kirby belt, as well as doing some basic maintenance to the roller brush to prolong the life of your belt as long as possible.
How to Replace the belt on a Kirby Ultimate G Vacuum Cleaner;
I hope that this video was helpful to you in repairing your Kirby. If you found the video to be helpful, please kindly rate the video helpful by clicking on the Thumbs Up Icon below.
Thanks for watching!
Chris J.
Nov 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How to change a band on a kirby vacuum?
I think you mean belt??
Take the nozzle of, remove the brush roll, put the a new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Jul 04, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby
Take the nozzle of, remove the brush roll, put the new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Jun 29, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How do i put a belt on my kirby vaccum
here is a link to a site with step by step instructions for replacing a belt on any G series kirby...it also works for the new model.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps! :)
Feb 24, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Belts
Recently received a kirby from mother in law and don't how to change the belts
Dec 15, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
