Samsung j1453s hi, our washing machine has just started overfilling with water - tot he point it is coming out of the detergent drawer. this is happening on the quick wash. Could you advise of a solution?
5 Suggested Answers
  • 1294 Answers
SOURCE: Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Posted on Oct 08, 2007
MNTECH
  • 1543 Answers
SOURCE: Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Posted on Oct 11, 2008
SOURCE: Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Posted on Nov 11, 2008
barkencoa
  • 3463 Answers
SOURCE: fabric conditioner drawer does not empty
The inlet to the conditioner compartment is probably blocked.
Get a thin piece of flexible wire and make a right angled bend on the end about 1" long, and poke it into all the holes u can see in the top of the dispenser compartment, particularly the ones at the front right side.
This should solve the prob.
Plz rate this solution .
Thanks
Posted on Jan 02, 2009
SOURCE: Fabric softener stays in drawre
We just had a tech come out to fix this problem for us. Essentially, the problem is that the fabric softener builds up and gets clogged. He cleaned out a solid hunk of frabric softener gunk, and suggested that we dilute our fabric softener with water to keep this buildup from happening again.
Posted on Apr 11, 2009
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
When machine spins after wash water gushes out of detergent drawer. Checked black hose from drum and found a blockage of colour catcher sheet thought this was the problem but water is still gushing out the...
Hi.
The problem can be a defective pressure switch. The pressure switch detects water level. Pressure switch not working correctly may result in overfill. Try cleaning the rubber hose connected to the pressure switch. Check also pressure from inlet hose and look for blockage in detergent drawer.
Aug 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
I have a Samsung Silver Care front loader washing machine. When I turn it on water comes out the detergent dispenser drawer and a little oozes out of the main front door. Any ideas? Thanks, Kelly
Remove the dispensing tray (look for an under side spring clip or release) and check the fluid exit point--the machine washes the detergent into the drum along with other washing compounds. You may be better off using a liquid detergent rather than a powder. This may also fix the main door leakage too. Hope this helps!
Aug 15, 2010 | Samsung WF328AA Front Load Washer
Water overfilling in detergent tank
CHECK THE INLET HOSE UNDER THE DRAWER, PULL THE DRAWER ALL THE WAY OUT BY DEPRESSING THE MIDDLE BUTTON ON THE MIDDLE REAR OF THE DRAWER. MAKE SURE ITS NOT PLUGGED WITH DEBRIE
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water is pouring out of my dispenser drawer
I have read other folks say that this has happened to them when a sock or wash cloth gets stuck behind the rubber seal of the door. There is a pipe that drains the water from your detergent tray and it may be clogged with a sock. Try feeling around behind the rubber seal in proximity to the detergent tray and see if there is a piece of clothing stuck in the pipe that drains the detergent tray. Also remove the tray and check the pipe from that end too.
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Leaking machine
Could be caused by several reasons.
1- Overfilling, check water level .
2-Blockage in dispenser, or dispenser inlet hose to drum
3-Drawer not in properly.
4-M/c not draining properly, thus when it goes into spin, water could be thrown up by centrifugal force, and come out of the front of the drawer.Check filter.
5-Water pressure very high, forcing water out of drawer, adjust pressure.
Plz rate my soution.
Thanks.
Dec 30, 2008 | Hotpoint WMA64 Front Load Washer
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Nov 10, 2008 | Samsung WF337AA Front Load Washer
Oct 07, 2007 | Washing Machines
Conditioner tray won't empty
i assume the detergent drawer is really clean especially the conditioner part.fault may be that the roof of the detergent box (the part the drawer goes into) is clogged. open drawer half-way at point conditioner should be taken and check if there is a spurt of water into the conditioner section. if not push a hairgrip or similiar into the holes in roof of box as you may have a blockage there.
Mar 28, 2007 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
