Question about Whirlpool LEQ9858P Electric Dryer
Dryer will not heat but works fine otherwise
I have a whirlpool LEQ9858PW0. I replaced the element, thermostat, cutoff & Fuse. What can be wrong?
  • 661 Answers
Could be problem with timer contact for the heaters.
Posted on Mar 13, 2009
Why won't my kenmore dryer 970-c85092-00 heat?
check the heating element to see if the coils are still intact (not burnt or brake). if it is fine,then check the T-STAT and the T-CUTOFF switch. one of those is your problem. if it is the T-STAT or T-CUTOFF, replace them both, they are inexpensive and easy to replace. here is a link to a video that explains this fix thoroughly. i think you will find it helpful.
Whirlpool Kenmore Dryer Repair Won Heat Test Fuse Thermostat 279816 or...
Jul 23, 2014 | Kenmore Dryers
Why won't my whirlpool electric dryter #ler4634dqo generate heat?
if you have a old house that has fuses sometimes only half of the fuse will blow making it look like the dryer is working but it wont turn on the heat element take the shielding off the heating element and start the dryer and see if they wires glow red hot when running and also after running the machine does the inside feel warm or cold if it is warm check the duct work on the dryer all the way out to the exit and see if lint is clogging it up
May 05, 2014 | Whirlpool Dryers
Electric dryer getting way too hot
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
Dryer not heating
Its a good possibility that you have lost the nuteral connection at the power block or the receptical .
Jan 04, 2013 | Whirlpool LEN2000PW Dryer
I have an inglis dryer and it's not heating so it appears from online searching to be a fuse problem, We don't have the manual Can I just assume the fuses are in the back and we can easily replace?
If the fuse goes on this dryer it won't run at all. It is located behind the back panel along with the heating element and the cutoff thermostat(located at the top of the heater housing). I would suspect either the element or cutoff, however its not possible for it to be the thermal fuse.
Jan 13, 2011 | Whirlpool Inglis IP8200 Dryer
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
I have replaced the heating element, the thermostat, the thermal cutoff, and the fuse. The dryer runs but still doesnt get hot. I'm thinking its the voltage but this problem happened overnight. We went...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Jun 18, 2010 | Whirlpool TEDX640PQ Dryer
Dryer won't heat?
Make sure your electrical connections are correct.
Check the voltage to the dryer element and make sure you are getting 220 volts.
Otherwise I am at a loss also...good luck
I hope this helps
Oct 01, 2009 | Whirlpool Dryers
No heat
If this is a GAS dryer make sure that the igniter or pilot light has not gone out. If this is an electric dryer, check the vent to make sure it has not clogged up and prevents the air from circulating in the dryer.
Otherwise if it is an electric dryer, make sure the heating element has not blown a fuse or burnt out.
Feb 19, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LEQ9858P Electric Dryer Logo
217 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
