Question about GE Dryers
Ge dryer mo#DDE5300GALAD
What is the routing for the drivebelt
3 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: how do I get to the drivebelt on a GE DPSB620ECC dryer
pop off top then take off front belt goes around motor drum and under tention wheel
Posted on Feb 18, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE Select clothes dryer model DSXR453EVOWW
Open the door and remove the screws holding down the top. Then raise the top and you can get to the screws holding the front on. Get the front out and then the drum can come out so you can clean that guy out and replace that belt. How about some repair PHOTOS?
Posted on Sep 12, 2009
Belt came off 97 achieva how is it put back on
to replace drive belt rotate tensioner pulley clockwise then slip on new belt look under hood on the radiator shroud for drivebelt routing diagram.check drive belt tensioner for damage or looseness because very seldom drive break either cracked worn or drivebelt tensioner faulty.
Aug 06, 2013 | 1994 Oldsmobile Achieva Special Edition
GE DRYER MODEL dvlr223egoww.BOUGHT NEW BELT SEEMS A LITTLE BIG.BELT WONT TUMBLE.
Hi maddy21350...
Make sure you have routed your belt correctly, if it is not properly routed then it can cause the problem you are talking about.
Go to the following webpage and see a picture of how to route your belt properly.
If you have it correctly routed the you got the wrong belt.
Please take time to rate me
http://www.expertappliance.com/dryerbeltconfiguration.html
Aug 18, 2011 | GE DVLR223 Dryers
I need to know to route my dryer belt on my GE dbrl33ee2ww dryer as the belt slipped off and I did not see the correct path
Hi Roy, W/D here. I wrote this earlier for another person, but it works just as well twice.
You already have the diagram! (Bear with me).
Make sure that your power is off.
If you look carefully at the drum, you can see where the old belt was running.
Place your new belt in that position.
Now, place the belt over the motor pulley (It is in the same plane as the belt position on the dryer).
Pull the tensioning pulley past the belt, and ease it into place.
Roll the drum several revolutions by hand, just to get the belt tracking completely right.
Put it all back together and you're done!
Best regards, --W/D--
Feb 01, 2011 | Dryers
Sep 12, 2009 | GE Dryers
New Belt and pully-wont activate swith to start dryer
The main cause of this is improper bely routing. Click here and verify that it was routed properly.
SG
Apr 07, 2009 | GE Dryers
How do I get to the drivebelt on a GE DPSB620ECC dryer
Feb 18, 2009 | GE Profile DPSB620ECWW Electric Dryer
GE Gas Dryer Replace the belt Model # DDG8280G
Usually there are one or two panel in the front that are held by some screws. Once removed the top panel is usually attached to the front panel and you can get a screwdriver and release the plastic push in retainers. Prop the top up and the drum is exposed. The belt usually goes around the drum down to a drive pulley on the bottom of the machine. You will need to route the belt around the drum in the front or back to get it routed correctly.
Jul 08, 2008 | GE DVL223GB Gas Dryer
Dryers Logo
143 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
