Question about Canon EOS Rebel K2 35mm SLR Camera
Canon eos rebel II
The autofocus willnot lock in focus: the camera searches, then stops with the green "not infocus" light glowing. I checked the "af" on the lens.
  • 60 Answers
Try removing the camera lens and VERY CAREFULLY raise the mirror in the camera. There is another small mirror behind the main mirror that relects the light for the autofocus to work. If the spring on that small mirror is broken (common problem) it can cause the symptom you are experiencing.
You can also check it by aiming the camera at an object above your head with the camera pointed up since that will hold the little mirror in place by gravity. If it works pointed up the spring is the problem.
You can get the spring from Canon. The part number is CS2-6367-000. Canon's parts dept phone number is 1-732-521-7230.
CameraRepairs
Posted on Aug 11, 2008
Need to set to fully automatic setting
The manual for your Canon EOS Rebel 2000 can be found here:
http://downloads.canon.com/cpr/software/camera/EOS_Rebel_2000_manual.pdf
Check out page 24 for instructions on shooting in fully automatic mode.
Hope that helps,
Bax
Oct 08, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
28 80 autofocus
Turn the mode dial to the green rectangle for automatic exposure. Set the autofocus switch on the lens to AF for automatic focus.
Oct 07, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
My Canon EOS Rebel XT 350d will not autofocus.
Sound like a broken ribbon cable in the lens. Needs to be replaced but get a quote as it may be cheaper to replace the lens with a secondhand one.
Mar 14, 2017 | Canon Rebel XT / EOS 350D Digital Camera
Err.1 of Canon lens
Maybe that's why it was for sale on Ebay.
Feb 03, 2010 | Canon EOS-1D Mark II Digital Camera
Will not take pictures
Does your lens try to focus or it doesn't try at all? You will have to understand that for the camera to autofocus successfully, theere should be adequate light and contrast. That means, autofocus often fail to focus even colored walls or objects under dim light. If you tried all this in daylight, outdoors, then the autofocus sensor is faulty. Please reply with details of how you tried the af.
Dec 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I can not get my canon eos rebel k2 focus on a
Autofocus is activated by pressing the shutter button halfway, be shure to have a EF lens in the camera, otherwise it won't make autofocus, put camera on full auto mode or "sports mode" (the running guy) and the focus settings on redictive AI Servo AF: Continuously tracks subject movement and achieves focus before the exposure starts.
Jul 10, 2009 | Canon Photography
Auto focus suddenly stopped working
This may not be the same as your issue, but our AF stopped working as well. I tried all the recommended fixes - removing the card and battery, recharging the latter, removing the lens and cleaning the contacts, etc. None of those things worked. However, I then switched to MF, requiring me to turn the barrel, and I realized it was stuck and just needed a little force to get unstuck. Might have been the humidity. Anyway, our problem was solved - AF was back to normal after that.
Jan 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
My Canon digital rebel will not autofocus correctly. My camera has 7 points autofocus, but it will only autofocus on the far right point. All other points are not used. I have had the camera for 14 months...
I had this problem awhile ago - you must have accidently adjusted the focal area - it is sooooo easy to do without realising it. Here is what I was told:
Most likely, you have changed the AF point, which only takes effect in the creative modes (Manual, Av, Tv, P, etc)
There should be a button on your camera that has a grid like pattern above it, like
or so. press that, look through the viewfinder, and move the shutter or rear wheel, you should see the different AF points like up in red, and as you turn different ones will light up, and eventually all of them. also, you can look on the screen on top (or back, if its a rebel) and it will show you which ones are selected while in that mode, instead of looking through the viewfinder.
Nov 07, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel K2 35mm SLR Camera Logo
119 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
