Question about Whirlpool Kitchen Ranges
I have Whirlpool Gas Range Model SF315PEGW 5. The bake function will not work and appears to through a code i.e., F3EO. Can you tell me what to replace?
  • 60 Answers
Will the ignitor glow if it does and its dim the ignitor needs to be replaced if not the control board needs to be replaced
Posted on Aug 04, 2008
When I try and Bake or Broil the oven beeps and gives a fault code of F3EO
HI. Generally, this will be the cause of a failed oven temp sensor. If your unit's orientation is doubled, the top oven sensor will be the culprit. Some model will incorporate a sensor fuse at the wiring harness. Check the fuse, if equipped, for continuity. If the fuse is bad, replace it. If the fuse is ok, replace the oven temp sensor.
F3E0 - Failed oven temp sensor(top sensor if double oven)
Mar 01, 2010 | Whirlpool Ovens
Kenmore SF367.....Contantly relighting during cooking?
This is a normal function of your gas range. I own a similar model and it operates the same way. The gas is not required to be on continuously to maintain the oven temperature and will relight periodically when the internal temperature drops below the prescribed set level.
Jul 04, 2009 | Whirlpool SF367 Gas Kitchen Range
Whirlpool accu bake oven door locked after self cleaning
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^YRG
Apr 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
F3EO error message
Replace the oven temperature sensor.
Mar 16, 2009 | Whirlpool Accubake RF362LXTS Electric...
My whirlpool oven electronic pad flashing f3eo
The error code E0 F3 indicates that the oven temperature sensor in your range is open. This error code can also mean that the electronic oven control in your range has failed. Disconnect the electricity to your range for 2-3 minutes. This will reset your control if it is just confused.
If the error code persists someone needs to access the back of the electronic oven control and read the resistance of the oven temperature sensor. The sensor is connected to terminals P3-5 and P3-6 on the electronic oven control by two violet wires. The sensor should read around 1100 ohms at 70 degrees
If the sensor reads more than 100 ohms more or less than 1100 it is defective. If the sensor reads within 100 ohms of 1100, the electronic oven control has failed and will need to be replaced.
Dec 18, 2008 | Kitchen Ranges
Broiler works, as do burners. The oven will not come on. Gas whirlpool range 2003 year. Model SF367LEKB
jdelvecchio5Does the igniter (glow bar) come on whenever the bake function is selected.?
If the glow bar does not come on the safety valve will not open - no bake burner. check the electrical harness first then Try changing the igniter (glow bar first) before changing the safety valve/regulator.
Dec 02, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Gas Range E2 F3
Nov 23, 2008 | Whirlpool GS470LEM Gas Kitchen Range
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Oct 24, 2008 | Frigidaire FEB24S2AB Single Oven
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Kitchen Ranges Logo
271 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
