Question about Panasonic Lumix DMC-LS2 Digital Camera
Connection usb connection cable will not fit my dell laptop
Luckily my son has same camera His cable fits my laptop. mine must have been damaged somehow Thanks anyway.
Posted on Aug 05, 2008
FITTING SD CARD READER
if you are trying to install external card reader it is connected to the usb
if it is internal card reader it will get connected to the usb connector on motherbaord (front panel usb)
Apr 14, 2014 | Dell OPTIPLEX 745 PC Desktop
Dell latitude d630 laptop - os xpp
You are a little confused. The ethernet cable will not fit into the USB socket. Do you mean that it is connected with a USB cable? Is the printer on, with paper loaded and the tray pushed right home? A bit unusual for an HP to jib. Make sure that all cables are well and truly home.
Dec 28, 2013 | HP OfficeJet 6310 All-in-One Printer...
In my dell xps L501x ethernet cable is shown unplugeed even when it's plugged in. The cable which i m using works fine on my desktop which i connect to my adsl2+ mt882 modem through this cable. Cable also...
1. laptops USB port is not recognized by the router .
2. This could be due to the usb hub drivers for this unit not being installed on the laptop.
3. check your "device manager" to see if you have all the usb hub driver installed.
4. Also check your router manual for the usb setup for a laptop connection.
Feb 20, 2011 | Skque Ethernet Cable Cat5e RJ45 White 30...
I want to fit an external dvd burner to my dell latitude d400. I have tried fitting a usb 2 card and fitting a samsung and lg burners but neither work. Is it possible?
its possible.
there are new variety dvd writers coming with usb cables. they are used easily. just plug and play. try it. it surely works. plzzz rate me.
Nov 05, 2010 | Dell Latitude D400 Notebook
Can't hook up my laptop to play DVD's through my Eiki LC-XNB4M
computer should always be connected with 15 pin VGA to DVI-I cable.
Select in menu input 1 analog RGB and adjust output resolution of Dell to 1024 x 768. this should work !
USB is only for mouse control with pj remote
Jul 09, 2010 | Eiki LC-SM4 Multimedia Projector
Can I put the harddrive of my dell 1525 laptop into the dell 1725
you can get an adapter that will allow you to connect your laptop hd to another pc through the usb port. Your hard drive is probably SATA so you would need a SATA to USB adapter cable.
Something like this cable would work.
Oct 05, 2009 | Dell Inspiron 1525 Notebook
Cannot connect a hp psc 2410 printer to dell inspiron 1000 laptop
Try a powered USB hub, this will boost the power in the USB curcuit.
Also ensure that in Device Manager, USB Root HUB, Power Management tab, that the option to let windows turn off the device is unchecked.
May 27, 2009 | Dell Inspiron 1000 Notebook
Cable connection from printer to laptop does not fit
And the laptop connector has 3 rows of pins while the printer connector has 2 rows, right?
You're trying to connect your printer to a monitor port.
As far as I can see your laptop doesn't have a LPT port. You will have to connect your printer to the USB port. If your printer doesn't have USB connection, you cannot connect it to your laptop.
May 05, 2009 | Office Equipment & Supplies
Ethernet adaptor and Local Area Connection 2 cable unplugged
Is that an external usb nic card? you can just directly connect it to the usb port.
Sep 07, 2008 | Dell Inspiron 1150 Notebook
Panasonic Lumix DMC-LS2 Digital Camera Logo
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
