Question about HP Pavilion dv6000z Notebook
When typing on the keyboard of my HP Pavilion, at certain times, certain keys will make the cursor move to another location. Example, when typing this sentence, the cursor move back to previous words.
  • jhunter Aug 04, 2008
    It's an HP Pavilion dv5000
    Scholar:
  • 39 Answers
Acouple people have had this problem the touchpad is very sensitive I would recommend you press the small button above it to disable the mouse when you are typing for a long time . you then can press that button again and it will let you move the mouse again. Im new on here so if my solution helped you please give some good feedback on my answer thank you
Posted on Aug 11, 2008
What says home or end keys
it is primarily used to return the cursor to the beginning of the line where the cursor is located. When the text is not editable, the home key is used to return to the beginning of the document; this can also be done in editable text if the key is pressed along with control.
The home key can also be used to highlight all the characters before the cursor in a certain line if pressed along with shift in editable text.
The home key will take you to the beginning of the line you are on - try it, type a bunch of stuff then hit the Home key and you will be brought to the beginning of the line. If you are in a multi-line document, hitting CTRL+Home will bring you to the start of the entire document.
Similarly, the end key will take you to the end of the line while CTRL+end will take you to the end of the document
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 18, 2010 | HP 381068-001 Pavilion ze2000 Keyboard
HP laptop pavilion dv 3500. While tying the the cursor skips back to an earlier part of the sentence or beginning of the paragraph. While emailing, the email sends before I finished typing as if I hit the...
Hi, thanks for using FIXYA.
you have a problem with the keyboard , and the usual solution for this case is replace, but before that try with an external usb keyboard.
Thanks
Nov 11, 2010 | HP D8597A Keyboard
My keyboard is too sensitive to touch and one wrong key moves the cursor too fast on the msi a6005 I find myself typing away and the cursor moves to another place on the screen. Is there a way to tone down...
my keyboard is way too sensiticve. when ltyping if i don't hit my key dead center and just a small lportion of my finger touches a key arouind it, that key is also typed. I am a good typist, but when not looking at keyboard and going too fast I don't always hit jmy key dead cwenter. i would like a keyboard like an old typewriter. do they sell less sensitive keyboards ???
Mar 11, 2010 | Computers & Internet
What does the insert key do?
Press and the text you type will over write what ever you have on the screen. This is typically used in most applications to "type over" existing text without moving the other letters/numbers/characters around.
This is my example of how the insert key works.
hit the insert key and position your cursor at the "w" in works.
Now type WOW!!.
You should now have:
This is my example of how the insert key WOW!!.
Clever these programmers. :)
Keep in mind it depends on the application you are running also.
Have fun!
Oct 03, 2009 | Logitech Cordless Desktop EX110...
HP Pavilion zd8000 keyboard skips characters
The most common reason that your cursor skips around is that you are touching the touch pad when typing. Some are more sensitive than others. On my Toshiba I had that problem, but it has a Fn key that allows me to turn off the touchpad. Problem went away when I went to a mouse instead.
Had a client with a Dell with the same problem. I had to actually physically disconnect the touchpad and her problem went away.
Now as for the first problem, (the HP), I'd say you have a stuck key on the keyboard. It would make that noise.
Feb 14, 2009 | HP Pavilion zd8000 Notebook
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
My typing goes uppercase without hitting the caps lock
I have the HP Pavilion and cap locks does the same thing.
THIS WORKS EVERY TIME. Hit both the right and left shift lock simultaneously about 5 to 10 times. It immediately disengages the cap locks. It is a little bit of a hassle, but I'm just used to it. It may happen 3 times per week, but I LOVE the machine, so I just fix it this way!
Oct 20, 2007 | HP Pavilion dv8000z Notebook
HP Pavilion dv6000z Notebook Logo
204 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
