Question about Refrigerators
Lec Elan Fridge Freezer: Freezer compartment requires defrosting more frequently - ices up within a couple of weeks. Fridge compartment appears to be working normally. Changing the temp setting for the fridge has no effect on freezer function. regards Richard
  • 12smithy Mar 18, 2009
    The freezer door on the top drawer becomes frosted up and the hinge jams, seems to be small amount of ice forming around the door - seal appears to be in fine working order - it's a mystery, but help asap would be appreicated as it's my elderly mothers and I'm going on holiday and she's worried about it.
  • Anonymous May 02, 2009
    My Lec elan fridge/freezer also freezes up very quickly. However, mine is old and as the problem has got worse over the last year, I think the seal is faulty and I will have to buy a new applinace.
Check freezer door seal
Regards, Barry
Posted on Feb 26, 2009
SOURCE:
Problem, fridge over a period of a few weeks or less goes from really cold to not so cold with ice buildup on the ceiling of the fridge section beneath the freezer compartment which itself does not ke
Hi, This will happen if you have a faulty defrost timer or the the heater is not working when it goes into defrost. The reason its not so cold after a week or so because the ice builds up & doesnt run efficently which is why when you switch it off & defrost it works great.
Nov 23, 2014 | Refrigerators
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
I have a model 25 side by side. I recently had to move the fridge over a 3/4 in. piece of underlayment bcs. I was replacing the floor. I tipped the fridge up to get it over the 3/4 in. lip. After all...
You appear to have a problem with the defrost components (defrost thermostat and/or heater(s)) located behind the freezer rear panel where all of the ice has built up.
Contact an appliance service company
Feb 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Cools fine then does not
yes sounds like a defrost problem when ice build up in frz compartment area and is not defrosted then air cannot be circulated.. could be a timer (roughly 15.99 to 49.99), heater (39.99-69.00) or defrost thermostat 29.99-49.99 parts only. shouldnt need all this , but this is wahat ait could be labor is roughly 85-165.oo depending were u live and who u use.
Sep 23, 2009 | Maytag Refrigerators
The freezer compartment on my fridge keeps icing up over a couple of months. How can i prevent this please.
if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes:
1. low refrigerant
2. no fan
3. too much humid air in fridge/freezer due to door open or bad door seals
4. the condensate drain tube is clogged
if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s).
no air, no fan. Replace
if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional.
defrost solutions:
unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Sep 01, 2009 | Refrigerators
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Ice build up in freezer compartment until water flows onto floor.
Hi, Is this a wwhirlpool brand fridge?
The drain is plugged in the freezer section. If I could get model #,I can get you ezact instructions.
If the floor panel in the freezer has screws holding it in, remove the fllor panel. Now you will need to remove the rear panel inside the freezer as well.
If this is a Whirlpool brand, there is an after market drain heat strip that you will need to add to the defrost heater.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Refrigerators
American fridge/freezer, over the last week the freezer compartment has melted ice? Today decided to remove all food from the freezer compartment - cleaned it out leaving the freezer and fridge...
  • yes, refrigerators have heaters in them to defrost the buildup of frost around the coils
  • they defrost approx. every 12-16 hours
  • if the defrost cycle gets stuck then it will continue to heat
  • i have seen it melt the plastic inside the refrigerator
  • possible causes:
  1. bad defrost timer
  2. bad thermo switch in freezer
  • i would replace both as they are not expensive
Jun 29, 2008 | Refrigerators
Refrigerators Logo
1,560 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
