FixYa.com
Tags:
IBM Serial Adapter
High pich noise on T23
By Bomber - usenet poster
Hi
Does anybody else have a problem with a high piched noice comming from the
Thinkpad?
I think the noice comes from the usb ports, cause the noice goes away when i
put something in one of them.
Any paches or suggestions?
kind regards
jostein nilsen
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 11, 2005
FixYa! (100)
Mini Me
Mini Me - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi
Anyone find a similar pach for winXP ?
Jostein
"Tina" <h4rdc @gmx.net> skrev i melding
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rating: 0%, 0 votes
Very interesting,
as for official recognition, I found this post from an IBM person in
the IBM support forum:
Topic:  A30 making a beeping noise (5 of 5), Read 26 times
Conf:  ThinkPad A20,A21,A22,A30
Date:  Tuesday, April 02, 2002 12:10 PM
The fix for this beeping noise is to go into Control Panel, Power
Options (Windows 2000) Power Management (Windows 98), choose the
Advanced Settings tab and disable the CPU power management.
This should stop the beeping noise without having to insert a USB
device.
Regards,
Jay
Thank you for using the IBM Discussion Forums.
JayS
IBM World-Wide Electronic Support and Services
and I also found another thread from an IBM guy about some USB driver
by IBM that was supposed to fix the problem on an other model, I
wouldnt use that driver for my A31p though, no idea .., anyone?:
Topic:  noise problems (4 of 10), Read 138 times
Conf:  ThinkPad iSeries 1400, 1500
Date:  Thursday, February 14, 2002 12:42 PM
Please follow the steps below to ensure the high pitch noise is not a
result of an audio setting:
1.Double click on the speaker icon in the systray. The volume control
panel will
appear.
2.Click the Mute all check box of the Volume Control . This will
disable all of
the Windows generated sounds.
3.Set the system volume control knob to 0. This will disable all of
the sounds
generated by the system's speakers.
If the high pitch noise can still be heard with these settings
applied,
the noise is the result of the issue below.
Solution
A Microsoft QFE is now available that will eliminate the high pitch
noise.
Follow this link to the patch :
ftp://thinkpad:ftp4t @ftp.pc.ibm.com/pub/private/th­inkpad/usbnewdv.exe
DavidE@IBM
Tina
Solution #3
Not Rated (0)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
This "fix", i.e. disabling XP's CPU power management, worked for me.
Not sure what if anything we are loosing by doing this.
This post is much appreciated; no one I dealt with in my
2-month-IBM-customer-service-w­ild-goose-chase had a clue, including
the tech who mailed back my laptop with the memo, "could not reproduce
problem...".
Thanks,
Jim
Solution #4
Not Rated (0)
Bray
Bray - usenet poster
Rating: 0%, 0 votes
BTW
The advice I got to turn of the cpu advanced powermanagement thingie, helped
I GOT RID OF THE HORRIBLE NOISE !!!!!!!!!
THANKS !!!
"jostein nilsen" <jos. @online.no> skrev i melding
Solution #5
Not Rated (0)
Kim1
Kim1 - usenet poster
Rating: 0%, 0 votes
Hi Tina,
I returned a Dell Latitude C600 which had a configuration similar to my new
T23.  It had the same noise as I described earlier.  This Dell model is the
sister to Dell's Inspiron 4100, which also has the same problem.  The Dell
web-based message board has lots of comments about this noise.  Several of
the posters noticed the relationship between the noise, Windows XP, and the
use of Macromedia Flash and Windows Media Player.  The Dell notebooks had an
additional problem.  The noise also occurred as the mouse pointer was moved.
In my case, mouse pointer movement caused significant noise in the Dell
Latitude.  (My T23 doesn't do this.)  Several of the Dell posters commented
that the noise went away when CPU management was disabled in Windows XP.
The noise does not come from the speakers and isn't caused by the power
supply.  But there does seem to be a relationship with Windows XP's handling
of the Intel SpeedStep technology.  I agree that turning off CPU management
isn't the best solution since it will shorten battery life.  Maybe future
upgrades to XP will address this issue.  So far, I'm not aware of any
official recognition of the problem.
Eric
Solution #6
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
I have a T23 with Windows XP Pro.  I believe there is a known issue with
some computers (not just IBM) running XP where a high pitched noise is
present when visiting some web pages incorporating Macromedia Flash.  The
noise can also be heard when running Windows Media Player.  It may have
something to do with XP's automatic adjustment of the processor speed for
certain applications.  You can try turning off this automatic feature to see
if it has an effect.
Eric
Solution #7
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
Does it do that in any location, without any devices attached to
it?
/da
Solution #8
Not Rated (0)
Gary10
Rating: 0%, 0 votes
I have had an intermittant high-pitched noise from day one (T23).  IBM
online support gave me the runaround, suggesting I try every silly test they
could think of.  Finally, I mailed my T23 to support with explicit
directions for reproducing the problem.  I even told them to call and talk
to me if they didn't hear it.
It came back two days ago.  They "couldn't reproduce the problem".  They
didn't call either.
Not sure what I will do now, but for me the current problem is unacceptable.
Jim
Solution #9
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
In case anyone is interested, I have recorded the noise for all to hear:
http://home.attbi.com/~jameseq uinlan/wsb/media/23813/site100 3.wav
At this point, I don't care what the problem is, I just want it fixed or my
money back.
Jim
Solution #10
Not Rated (0)
Rachel007
Rachel007 - usenet poster
Rating: 0%, 0 votes
thanks Eric,
this is what it looks like to me as well.
Do you have any other sources to confirm this, cause you mentioned it
is a knows issue?
I heard the same noise as described on a new A31p Thinkpad with the P4
1.70GHz CPU running XP pro.
The intermittent noise comes from the fan area I would say, it is not
always present after booting, but I noticed that it started after I
opened Internet Explorer and only after I visited a site with Flash.
When I went back to another site or closed IE, it stopped.
Once the noise continued though, even after all applications were
closed.
It does get extremely annoying, no matter how hard you try to ignore
it.
Now, I went into the Performance and Maintenance section of the
Control Panel, into Power Opions and Advanced Settings, and disabled
CPU power management. After a reboot the noise does NOT appear anymore
when visiting and sites with Flash.
I don't think this is a great solution though.
Tina
Solution #11
Not Rated (0)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
Just wanted to let others know about my situation with my T22. I removed the
hard drive and started the computer and there was no high pitched noise.
Used IBM's hard drive test utility and it found no errors. Called IBM
technical support yesterday and today received a replacement 20GB hard
drive. Backed up my old drive using Ghost over my network to my main
computer. Placed the new hard drive in the T22 and restored the Ghost image
to it. Total time to get back and running, under 15 minutes. Now my T22
doesn't have any high pitched sound that was getting very annoying.
Cheers,
Rene
Solution #12
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
Lucky you, in the UK we have to pay to ship our faulty drives back to
the Netherlands before we get replacements.
JohnPe @redoak.co.ukNOSPAM (delete NOSPAM)
www.redoak.co.uk      www.eze-buy.co.uk
Solution #13
Not Rated (0)
Cato
Cato - usenet poster
Rating: 0%, 0 votes
for my t21, it even makes noise when booting.
no idea what is the problem.
kp
Solution #14
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
Hmmm, what does this tell us about IBM's thinking on the honesty of Brits?
;-) You guys just have to get rid of Toady Blair. He's giving all you guys a
bad name.
Cheers,
Rene
Solution #15
Not Rated (0)
Janice
Janice - usenet poster
Rating: 0%, 0 votes
Try the following:
Take out your hard drive and boot up.
If noise is gone, that's your hard drive
If noise is not gone, it's time for a warranty repair.
--Andrey
Solution #16
Not Rated (0)
Brad
Rating: 0%, 0 votes
Yes, a terrible noise. I don't even like using my T22 anymore because of it.
I have a mouse plugged into my USB port, and it doesn't appear to make a
difference whether the mouse is plugged in or not. It's a high-pitched whine
coming from the area where the hard drive is located.
Cheers,
Rene
How about off-site backups of your store?
Our support staff can do it! -- http://priority.starbase21.com /
Solution #17
Not Rated (0)
Beresford
Beresford - usenet poster
Rating: 0%, 0 votes
No noise on mine, though there is a very slight noise when the fan comes
on.
Solution #18
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
It likely IS your hard drive...the noise may be an early sign of it "giving
out".  Configure your powersaving settings to turn off ur hard drive but leave
whatever else u can "on", and wait for it to shut down, and see if the noise
goes away when the HDD is powered down.  This will essentially tell u if its the
drive or not.
Solution #19
Not Rated (0)
Chandler
Rating: 0%, 0 votes
Or you can get a new hdd to see if the problem still exists. You can contact
IBM support, tell them you ran the DFT and got a return code of 0x72
(hardware failre) and they ship out a new drive.. make sure that you have
the recovery cds though. :)
Can you Help with these Serial Adapters problems?
Serial Adapters
CATV MOXI BOX NOT RECEIVING...
but i know catv is coming into... Answer This...
Serial Adapters
What do I do?
I am in southern Alabama and... Answer This...
Serial Adapters
usb to serial portable adopter
I have adopter but now I have... Answer This...
Serial Adapters
External hard drives not...
MacBook Pro will not recognize... Answer This...
Serial Adapters
attach a excel base programe
dear sir please gide me i want... Answer This...
Repair Service
Find Serial Adapter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
