Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Eco smart washer goes thru complete cycle but never aggitates.
  • 639 Answers
Dear flog1,
ngfam1 here for you!
I am happy to be of assistance!
Sounds like the belt is broken,which is good and inexpensive to repair. OR worse the transmission is shot!
Is there any oil on the floor coming out under the washer?
This is only one sign that means transmission.
Do not fix or replace a transmission on a old washer $$$$$.
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Pleas egive me a good rating here in fixya.com before you sign out!
Posted on Aug 26, 2008
I have a kenmore 80 series washer that goes thru all the cycles except that it doesn't drain after rinsing and this is my serial and model number if you need it: mod20852990 ser4549516
does it drain after the wash cycle before therinse cycle? if not there are usually 2 belt on the bottom of the washer, one is for the aggitator the other for the water pump. check to see if the belt is still attached and also take the drain hose down to floor level to see if the water gravity feeds out, if it does not pour out then your pump would likely be clogged from lint.
Apr 24, 2012 | Kenmore Washing Machines
Cycle switch keeps tripping
Switch actuator (usually on washer lid) is probably broken if you can complete the cycle by depressing switch manually.
Jan 17, 2012 | Amana 3.2 cu. ft. Top-Load Washer
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Kenmore washer model 110.91210100 bought in 1992 won't spin, goes thru the cycles but won't spin out? Is it a coupler? Is it worth fixing?
if its aggitating properly it is likely the transmission and i would not reccommend reapair for that
Oct 08, 2009 | Washing Machines
Neptune washer won't stop
this is a major control fault. replacement of the control board will be needed in this case. it has failed.
Jun 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer fills with water, starts it's cycle, goes through aggitate cycle, then stops timer continues a short time after to next cycle then stops, timer has been replaced and still doing the same thing
when it stops it wants to drain but your lid switch is not completing the curcit to the motor thats where i would go.you can jump it but only to test .because people can get hurt if not in use.tom
Jan 02, 2009 | Washing Machines
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dirt like pebbles left in the bottom of the washer after the cycle is complete
take the fabric softener cap off just pull. then look down the middle there will be a bolt 10 mm loosen it and pull the agitater
Jul 22, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
