Question about Meade 494 AutoStar Telescope Control Unit (Handbox only)
Telescope control unit AUTOSTART failure
The telescope was turned off when DOWNLOAD funtion was accidentally in operation and the control unit did not respond to intents of interruption by MODE or ENTER. Now the AUTOSTAR does not intiate. It presents only the initial message indicating the version of software "(c)05 MEADE [345] AUTOSTAR", but it does not go further. Grateful for any tips on how to proceed.
Ricvalles
  • ricvalles Aug 04, 2008
    How do I reinstall sofware into AUTOSTAR if I do not make it work (no comms with PC)?
  • ricvalles Aug 05, 2008
    I do not know the software version, but the problem is that I cannot get the autostar unit to communicate with the PC; hence, I cannot upgrade, download or whatsoever unless there is another method to communicate with the autostar different than via com port through Autostar Suite software.
    Brigadier General:
  • 6,966 Answers
I think your control unit is "bricked"; that is it was in the middle of an upgrade and lost power, the new firmware has not been completely written while the old has been deleted.
However, based on your query "another method to communicate" and since your control unit uses RS-232 serial interface adapter, might not what you need is another communications method other than the PC astronomical software program or with the Autostar Suite software or whatever it is currently using? Have you tried "Hyperterminal"? I just do not think it is available in Vista, XP and lower Windows only.
For reference and further information, pls check here and/or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 05, 2008
  • 6,487 Answers
In order for you to reinstall the software you should have a computer, you can check this user manual for it http://www.meade.com/manuals/TelescopeManuals/AutostarManuals/ASSuiteInstallQuikGuide.pdf
Hope that helps.........
Posted on Aug 04, 2008
  • 13,433 Answers
What version of autostar are you using? try updateing to the newest one
http://www.meade.com/autostar/
  • 19,396 Answers
Unplug telescope from powe. Then reinstall software, it should fix it
I have a Meade ETX-70. When turned on, the handset says there is a Motor Unit Fault: Motor failure detected due to moving handset between scopes, low battery level, obstructed or overloaded scope. I've...
This is usually caused by low battery power-- as the hand controller reported. DO NOT USE rechargeable batteries they do not have enough volts. Use alkaline batteries only.
This can also be caused by a broken gear or a failed internal motor. You can return these to Meade for repair.
Here is the contact number:
http://www.meade.com/support/index.html
Sep 14, 2011 | Meade ETX-70 (240 x 70mm) Telescope
My question is, I have a Meade Autostar #494 How do I see through the lenses?
The 494 is the HAND CONTROLLER NUMBER--- not the telescope. What Meade telescope do you own??
Aug 20, 2011 | Meade 494 AutoStar Telescope Control Unit...
Bonjour, Mon telescope ne se deplace plus vers le haut et le bas avec l'autostart. On entend le moteur tourner mais rien ne se passe. Lors de la recherche automatique c'est pareil, juste le...
The altitude clutch is not engaging. It could either be slipping, or broken. Also the worm gear inside the form arm might have come loose.The scope will need to be returned to your dealer or Meade for repairs.
Aug 02, 2011 | Meade DS-2114 ATS (325 x 114mm) Telescope
Assembly & operating instructions for a Sear's Refactor Telescope Model 24191.
Sorry the only thing available from Sears is this parts list-- not a manual.
http://www.searspartsdirect.com/partsdirect/brands-products/Sears-Parts/Toy-Parts?Type=Telescope
I suspect this is a small REFRACTOR style telescope. You may want to download a Meade telescope manual which is similar to your telescope. They all assemble in a similar fashion.
Look under the REFRACTOR header for one that is similar to your telescope:
http://www.meade.com/manuals/index.html
Sep 15, 2010 | Sears 127474 Telescope
Can't get it to work with AutoStart Suite
You must have the proper cable connected between the hand controller and the computer. Meade will sell you a cable. Call customer service-
May 23, 2010 | Meade Autostar Suite Autostar Suite...
Recently acquired a used Meade 8" LX200 EMC. The unit presents very well cared for by previous owner. Upon receiving it, I followed the manual's instructions in assembly and then operation. Upon turning...
I have a LX200 EMC 10". I had a similar software problem and solved it by downloading AstroFinder, bypassed the onboard software of the telescope, and controlled the telescope via my laptop. This was a more user frriendly method and allowed easy alignment of the telescope.
Apr 21, 2010 | Optics
Need operation manual on Discoverer 60 MM Zoom telescope.
All of the manuals for Bushnell are located on this web site. Find your telescope model, and download a free manual.
Look down the page:
http://www.opticsplanet.net/bushnell-warranty.html
Mar 01, 2010 | Bausch and Lomb Optics
I purchased a science tech 675 X reflector telescope and need an instruction manual. Where could I download one?
This is a Fisher Price toy telescope. You will not find an operational manual.
Return the scope, it's considered junk. After you return it, consider a reflector on a Dobsonian mount as your first telescope. Like this one:
http://www.telescope.com/control/dobsonians/classic-dobsonian-telescopes
and read my telescope TIPS on my profile page.
Jan 10, 2010 | Optics
The hand held unit lights up when turned on, and the telescope "homes" but the LED does not show anything. The voice speaks "Bushnell Northstar" but very quietly. The telescope can be moved by the bottom 4...
Can you reverse the cable end to the hand controller-- a bad cable can cause this. Also low power supply, depleted batteries can also cause this.
Return the hand controller for replacement if batteries and or a new cable do not fix this.
Dec 24, 2009 | Bushnell NorthStar 78-8846 (675 x 114mm)...
Need Part Replacements
My son got his Vivitar telescope for his birthday and his little brother accidentally broke the black thing that holds the tripod together.
Can I order a replacement part?
Dec 25, 2007 | Vivitar (1607225) Telescope
Optics Logo
382 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Geoff
Rich Lewis
Are you a Meade Optic Expert? Answer questions, earn points and help others
