Question about Lexmark X1270 All-In-One InkJet Printer
The power button keeps on blinking and wont start print. what should i do, i just installed new software of all in one center for it. and it wont work. ive been using this printer like ages, but keep using the scanner stuff instead of focusing on the printer itself. but now i so gonna need use the printer and it would not work, I NEED help. Thankyou
SOURCE:
Printerguy
  • 31 Answers
SOURCE: lexmark z53
You will need to do the following diagnostic tests to determine the exact cause of the error: · Remove the ink cartridges · Perform the self test (test B below) · Test the ink cartridges A. To remove the ink cartridges: Switch the printer on by pressing the green button. Open the front cover of the printer. The cartridge carrier should move to the center of the opening. Remove both cartridges. If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand. Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer. Open the front cover of the printer. Inside the printer, locate the silver metal carrier bar on which the print carriage slides. Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion. Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening. Now pull both cartridges out. B. To perform the self-test: Disconnect both the power cable and the USB or parallel cable. After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.) Turn the printer off by pressing the green power button. Hold down the grey paper feed button. Turn the printer on by pressing the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below. C. To test the ink cartridges: Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place. Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step. Turn the printer off using the green power button. Hold down the grey paper-feed button. Turn the printer on using the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly. Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly. If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase. Good luck
Posted on Aug 30, 2007
Ajkill
  • 2035 Answers
SOURCE: can't locate the Lexmark Solution Center
You need to use windows photo gallery in vista to scan and make copy.
Posted on Jun 17, 2008
SOURCE: lexmark 3400
i had a similar problem when the printer wouldn't print. Make sure that the printer 3400 lexmark series is the default printer in the control panel. (start/control panel/printers/printers and faxes/right click lexmark 3400 series/set as default printer).
Posted on Nov 05, 2008
im looking for the software to run 3400 can you help me get it
Posted on Dec 21, 2008
LuckyJackson
  • 72 Answers
SOURCE: printer wont print at all. error message is 50C.
Hi Try These Solutions:
its quite simple really just turn off your printer then unplug it remove both cartridge's get like a wet baby wipe or something similar let them sit on it for @ 10 secs then just real easy wipe the front piece as well take the same wipe and wipe the heads in the printer well sort of dab them dont wipe let dry for @ 10 secs put them back in (note you will need to move your cartridges over to where load position by hand to and back) run a cleaning test then align test , then print a test page and wah lah works on every one i ever had to do . sort of fix the things u know. have fun hope this eases your day or better. merry christmas to all and to all good night in essence what has occured is the cartridge got shorted and has dried at the surface as well. try it any other tips you need well ask but not to many thats why i quit giving tips like 15000 email a week blow your mind apart
or
Well, I did all that but no dice. But then I noticed that the "protective" tape on the new cartridge had left sticky junk on the cartridge -- but NOT on the print heads, just on a regular part. I got rid of the sticky stuff and voila!
Posted on Jul 07, 2009
My HP deskjet 3910 printer power lite keeps on blinking and it wont print. how do i fix this? i unplugged printer and then plugged back in and still the same thing.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Jun 17, 2011 | HP Deskjet 3910 InkJet Printer
Hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
May 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
I have purchased a ''Virtually Mint'' Canon Pixma ip90 printer however, when I try to print a document a message pops up stating ''the following ink tank is not installed: black ink tank, colour ink tank....
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 21, 2010 | Canon PIXMA iP90 Mobile Printer
My printer wont print and the lights keep blinking
Check page 10 in the manual at this link:
http://h10032.www1.hp.com/ctg/Manual/bpd09384.pdf
If the "Resume" & "Power" buttons & lights are the ones you refer to, then here is a page explaining how to resolve this issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=71895&prodTypeId=18972&prodSeriesId=71895&objectID=c00681585
Mar 04, 2009 | HP DeskJet 5550 InkJet Printer
Printer wont Print after replacing catridges
1. Make sure the printer is switched on, the old cartridges are still in the printer, and the cartridge cover is closed.
2. Click on Start, Programs (XP: All Programs), Lexmark <Printer Name>, Lexmark <Printer Name> Solution Center.
3. When the Solution Center screen appears, click on the Maintenance button on the left-hand side. (This button is the third from the top and bears a picture of ink drops.)
4. When you see the Install or obtain a New Cartridge option, click on it once. A pop-up displays a brief description of how to physically remove an old cartridge and install a new one.
5. Follow these instructions and click Next. The software will prompt you to confirm whether the cartridges are new or old.
6. For the new cartridge you just inserted, select No, it's new. Important: Make sure the setting for any old cartridge stays on Yes, It is old.
7. Once your selections have been made, click OK. The program will want to run the alignment for any new cartridges you installed. This applies whether you changed one or both cartridges (in the case of printers that can hold two cartridges). An alignment screen with a red and white bull's eye will appear.
8. Make sure the cartridge cover is closed and that there is paper in the printer.
9. Then click the Print button on the alignment screen. A sheet of paper will print from your printer with a series of arrows and numbers on it, with one set of solid bars above them. You should see four groups of lines, unless you have a single cartridge. If you have a single cartridge, you will only have one set of lines.
10. In each group, locate the arrow that looks the most solid. It may help to circle the number under each arrow you choose as you go along.
11. On your screen, you will see an area where you can enter the alignment values. When you have identified all the numbers, select those same numbers for each group on your screen, using the up and down arrows next to each value for A, B, C, and D (or A if you have only one cartridge).
12. When all the numbers have been changed to reflect the chosen numbers on the printed alignment page, click OK. The cartridge installation procedure is complete.
13. You can now exit from the Solution Center.
Source: micksmixxx
-Yahoo Answers
Please tell me if this helped I take no credit as I used the name aboves solution any credit should be give to him
Jan 07, 2009 | Lexmark X125 All-In-One InkJet Printer
''Check Print Cartridge'' light keeps blinking On HP psc 1210v AIO
Bad ink Cartridge, I got a new cartridge and within a week had the same problem replaced the cartridge and problem solved. To bad these things are so expensive.
Nov 17, 2008 | HP PSC 1210v All-In-One InkJet Printer
Colour Ink
1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
2. Select the Solution Center.
3. When the Solution Center appears, click on the Maintenance button.
4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
6. Print the Print Alignment page to ensure the print quality is satisfactory.
7. Close the Solution Center.
Mar 23, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark 5150 - Error 0502
Jan 07, 2008 | Lexmark X5250 All-In-One InkJet Printer
922 All-inOne ink Jet printer doesn't print
Lots of luck. I couldn't even get the printer to load the software or install the hardware. I was helped by Dell's tech support (Dell has one of the best tech support programs that exists, in my opinion) for at least 4 hours without any good results. They sent me a replacement for a replacement and I finally got the printer and the software to show by installing it differently. Now it will not print, and, like you, the light to the power button blinks all the time and the printer states that there is no color cartridge installed, even though I have re-installed the new trial cartridge sent by Dell several times. I am going to purchase a new Canon Printer.
Nov 14, 2006 | Dell 922 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
121 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
