Question about HP iPAQ RX3715 Pocket PC
Passing allign screen test
I can not pass allign screen test of my ipaq 3715
    Problem Solver:
I am not an expert on this. But I just had a problem similar to this as the unit kept reporting a FAIL on the screen calibration test. So this is what I did and after I did this, the screen calibration passed.
I went back to the screen alignment tool and performed a screen alignment with the stylus and this solved my issue. I then checked the self test aand it passed. This may not workfor you, but you can try it. Also you might want to check to see if you have any third party programs that are affecting this. The only way, you'll know is to remove those third party programs, one by one and repeat the self test to see if this corrects the problem. Good Luck
Posted on Aug 05, 2008
Touchscreen problems (HP RX or HX series)
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
May 25, 2009 | HP iPAQ HX2110 Pocket PC
Ipaq 3715 tapping problem
have you downloaded any viruses? if not try another hard reset is the screen cracked?
Jan 07, 2009 | HP iPAQ RX3715 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
Pass the align screen
Hey :), id be happy to help. You see, I too have a Ipaq except I had Ipaq 4350. Now, I too had the same problem you are having. The reason why you can't pass the align screen step is because somehow you have damaged your screen. And I have come to the conclusion that HP Ipaq's screen is extremely sensitive, ( because I never did anything that bad to my screen for it to be damaged) soo I'd recommend for you to call HP and see if they can repair your problem or give you another one. Thank you and I hope this helps!
Sep 03, 2008 | HP iPAQ H2210 Pocket PC
Helo i have a problem
The dreaded "allign screen problem" strikes again. This is a known bug of these rx ipaqs. You should simply try to see if the ipaq passes this stage if you try to allign the screen a few times. If not, try a firmware update/rom update (from the hp site) If this woun't work then the problem is located on the motherboard,where a small chip called the touchscreen I/O controller has failed. This isn't fixable by replacing the screen, only the whole motherboard. Unfortunately most of the first generation rx 3715 units (first revisions) carried this problem just waiting to happen.
Please ask more details if you need to better understand any of these methods above.
Jul 11, 2008 | HP iPAQ RX3715 Pocket PC
How do i play mp4 on my ipaq 3715
try converting the mp4 into either an mpeg or mp3
Nov 20, 2007 | Compaq iPAQ H3630 Pocket PC
Bogdan, could you give me a solution to contact you about this PDA? Give me your email adress or your cell phone number (mine are tiby_olimp@yahoo.fr and 0746761410)
Jun 09, 2007 | HP iPAQ RX3715 Pocket PC
Problem with passing the allign screen test
Salut, daca esti din Romania, inscrie-te te rog pe www.phpbbplanet.com/matzahajuta.. e un forum specializat in genul asta de probleme. Vei primi un rezolvare in aceasi zi. PDA-ul tau se poate repara. PS. eu administrez forumul ala, dar prefer ca acele informatii sa ne fie accesibile si noua romanilor pana sa ajungem pana pe site-urile de afara.
Feb 06, 2007 | HP iPAQ RX3715 Pocket PC
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
Hebrew Support for IPAQ 3715
Try Laridian.com They specialize in Bible and some language software for PDA's. Good Luck.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
389 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
